302 - TRS or Kaama?
Found a pair of 302s for sale near me. One boat has TRS, one has Kaama drives. All things being equal, which way would you go? My heart says 'tail baby! But I worry about parts and servicability on the Kaamas....
Kaama parts are still available. Many of the other parts in a kaama (bearing, seals, etc.) are standard automotive components and can be bought easily. Cases and shafts will be the biggest issue but if you are responsible these will last a long time. I am in the process of converting my TRS boat to kaama's. I bought two complete sets of drives. One set is going on the boat and the other is for spare parts (if I need them)
Oh btw. Rumor on the street is you get 8-10mph with a kaama setup over TRS.
I am sure other kaama lovers (and or haters will chime in)
I had a 357 Kamma boat and loved the Kammas. Twin Disc transmissions I recall. Had them rebuilt no problem. Lost a tail fin on one and just ran without it. I would seriously look into replacing the prop shaft seals and input shaft seals before you put too much time into them. Lost a drive when a seal went out on one of mine. Remember, the rubber gets brittle after many years of service. Can't beat the rooster tail, miss that a bunch. I had 502's with prochargers and had it going a little over 70, which is pretty good for a 357. Probably, right around 500 hp each. Good luck
Kaama boots and some of the parts are expensive and gears are not easy to find, I know which 2 you are looking at, they are both nice
Rooster tails are cool, but I dont know of anyone in the area that can work on KAAMA's
Kaama's stick out quite far and if you have a family, swimming may be challenging
Replacement TRS drives are cheap and parts are still available (unless you talk to a mercruiser guy)
The differwnce in speed should only be about 8 mph with like power, Kaamas will take longer to plane when starting of and slow maneuverability will be harder with Kaama's
If you pop a prop Kaama props are much more expensive than the TRS replacement as there are more available out there
welfare, thanks for the info. Apparently the Kaama boat needs a boot on one of the drives, so that is a consideration. I'm currently waiting on Uncle Sam to return my money to me, so I've got some time to consider. Easy to make an impulse buy
I do love the roostertail..... but servicability on a boat this old is definitely a consideration.
Kaama!
Just make sure to service the u Joints. The ones between the tranny and drive have a down angle and tend to wear. Never had an issue getting parts or props. Had the boat for 20 years and had the drives rebuilt 2 times.
