Instrument lighting replacement
I have a 252SS, 1998, Does anyone have experience with how to get at the instrument lights for replacement without dismantling the cabin door and bulkhead? I can't get my hands up behind the panel to access each instrument. Does the whole panel come out toward the steering wheel?
Thanks |
there should be screws holding the panels in place
Thanks Splitdecision271, do you mean screws that I can access from below the panel to remove the whole cluster toward the steering wheel?
screws should be in plain sight at the helm, per the attached picture.
http://newimages.yachtworld.com/resi...30461_1_XLARGE once removed they whole cluster can tilt towards the steering wheel. the wires may limit how much you'll be able to move it, but enough that you'll be able to get to the bulbs |
hmmmmm.... i'm seeing conflicting pictures. looks to me like the screws in the above picture are not factory per the picture below in which I don't see any screws
http://images0.boattrader.com/resize....jpg?t=1193361 |
Yeah, mine looks like the "picture below" with no screws.
A quick email to Formula's TAG group will get you the answer you need
Thanks again, TAG group I think means Technical Assistance Group and I'm going to do that now!
Correct
| All times are GMT -5. The time now is 05:00 PM. |
