New exhaust manifolds and risers cost ??
Looks like it's time to replace the manifolds and risers in my 382 Fastech. Question one is what is average cost of these part if OEM is used ?? Second, what's average cost to switch to an aftermarket header as well as pro', con's, and cost ???
This is also a salt water boat too. Thanks, SJ
If your exhaust manifolds have corroded from saltwater and you do not have a closed system you better check your intake manifolds under the thermostat housing, if cast these also corrode away and you will not see it until you fill your block with saltwater. I could put a small screwdriver through mine with very little pressure.
