271 SR1 Fuse Panel? >
271 SR1 Fuse Panel?
271 SR1 Fuse Panel?
Old 09-01-2015 | 07:53 AM
Default 271 SR1 Fuse Panel?
I have been through the boat pretty good and haven't found a fuse panel yet. There is a circuit panel under the bench seat on the port side that has about 8 resettable circuit breakers in the panel but there isn't anything for the courtesy lights, depth finder, cabin lights, fresh water pump, engine compartment lights etc...
My high water alarm, engine fume monitor and fire extinguishing system doesn't have power to them and there are not any circuit breakers on the panel for them.
I want to start working on all the lights that don't work but don't know where to start looking. I figured if there was a fuse panel somewhere else in the boat it would be a good place to start.
WilmFireboatCapt is offline
Old 09-01-2015 | 02:50 PM
I think there is also a few breakers under the driver help, there is a access panel check, will be on your right, my 303 has 2 diff panels, can't remember if the 271 did or not
88242LS is offline
Old 09-01-2015 | 05:59 PM
Ok, mine had a vhf in that little compartment.mlet me dig deeper.
Old 09-01-2015 | 07:28 PM
It was in the compartment under the steering wheel. Thanks for the help!
Old 09-01-2015 | 09:10 PM
no prob, was there a issue there?
88242LS is offline
Old 09-01-2015 | 10:08 PM
Still working on high water alarm and fume detector....
