311 docking lights >
311 docking lights
311 docking lights
Old 06-13-2019 | 02:42 PM
Originally Posted by TomZ
Converting everything over to LED will really help with battery life when your out on the hook. I did all of mine when I first picked up mine.
So, you are currently using these:
https://store.marinebeam.com/4-5-led...r-light-par36/Excellent!
Are there write-ups to how to replace them?
F14A water jet is offline
Old 06-16-2019 | 09:01 PM
masi242's Avatar
Can someone explain how to get the old light out of that housing, i gave up because i knew i would break it.
masi242 is offline
Old 06-17-2019 | 06:57 AM
Look at my thread on my 242. I have quite a few pictures of when I did mine
Redneckcustoms13 is offline
Old 06-17-2019 | 03:32 PM
masi242's Avatar
Will do thanks
masi242 is offline
Old 06-18-2019 | 08:45 PM
so, do you access the light bulb by removing the Phillips head screws on the housing on the outside of the hull?
Old 06-19-2019 | 04:53 AM
masi242's Avatar
No you go thru the cabin you should have an access panel in the front
masi242 is offline
Old 06-19-2019 | 07:27 AM
Very informative 242 thread! We will be near each other (I will be on Perdido Key).
I did not see how to access the bulb...
Old 06-19-2019 | 07:28 AM
Okay...I will try to find the access from inside.
I'm assuming I must remove some inside coverings/liners on a 311
GREAT FORUM!
Old 06-19-2019 | 08:09 AM
Like stated above. Look at my 242 thread. Shows it pretty well.
Old 06-27-2019 | 02:27 PM
Maybe you already answered but:
1) spot (25 degree) or flood (60 degree)?
2) 13 Watt or 18 Watt?
