Any FASTech owners stow the bimini top in the engine bay??? >
Old 10-19-2015 | 11:47 AM
Originally Posted by t500hps
I had the factory bimini on a 382 and no way it would fit......the bimini would need to be nearly 1 ft narrower to fit inside the compartment, reducing the amount of shade it provides. Leaving it on top of the sunpad, or propped up on the rear poles always seemed best for me.
Jriggs was able to fit his factory bimini in the engine compartment the same way I was. Have to slide it in from one side, and let the legs hang down. Cut the legs off and sleeve them with a pin. Piece of cake.
RT930turbo is offline
Old 10-19-2015 | 11:50 AM
These are from my 303, but I have the exact same setup on the 382...
[ATTACH=CONFIG]546673[/ATTACH]
[ATTACH=CONFIG]546674[/ATTACH]
[ATTACH=CONFIG]546675[/ATTACH]
Attached Thumbnails Any FASTech owners stow the bimini top in the engine bay???-478841d1342496899-my-303-sr1-pictures-img-20120716-00134.jpg   Any FASTech owners stow the bimini top in the engine bay???-478840d1342496899-my-303-sr1-pictures-img-20120716-00138.jpg   Any FASTech owners stow the bimini top in the engine bay???-478842d1342496899-my-303-sr1-pictures-img-20120716-00137.jpg
Old 10-19-2015 | 07:39 PM
Have not figured out how to fit mine in yet on my 336, but there are brochures showing it stowed I know it has to be possible. Need to be a contortionist to get it in
rexcramer1 is offline
Old 12-05-2015 | 02:02 PM
Registered User
I have had a bimini stowed in the engine compartment. The problem with that is most bimini's are sewn and glued. The heat from the engine dries and releases the glue. I took the bimini out to preserve it and went to a sunshade. The sunshade is light and works for nearly every boat. The downside is you can't use it while running...but who wants a bimini up at 90mph? Also, the sunshade stores easily and looks pretty cool.
353500efi is offline
Old 12-05-2015 | 03:55 PM
Been thinking about adding a sun shade to compliment my bimini, and only use the Bimini when overnighting
Old 12-11-2015 | 02:27 PM
RedDog382's Avatar
Not sure the top on Jriggs boat was a factory original. I know the previous owner well, the top ('98) was clearly different than my factory top ('99).
RedDog382 is offline
Old 08-01-2017 | 08:57 AM
Originally Posted by VoodooRob
[ATTACH=CONFIG]546597[/ATTACH]
Wow....wish i could find one to fit in our 382 engine bay for storage!
southernhick is offline
Old 03-22-2023 | 02:56 PM
Default rob i would like to know about your top
rob, can you message me if you still have your account about your bimini top.... i have a 312 and looking for one and need part numbers and dimensions if you can
badbuck6669 is offline
Old 03-22-2023 | 05:41 PM
I could never get anything to fit on my 292.
SabrToothSqrl is offline
