where do I find "performance report" for my formula???
I got the sheet I was looking for from formula on friday via email, it was an option and they said they tested it and it did 65. with the 320 efi/bravos
Awesome, sounds like it is running great. That much fuel with 4 people is a pretty good load. 1 person and half that fuel would probably get you 64-65. Although Formula said 60 with 270hp mags, 58 or so was more realistic with people I've talked to that had them.
well the boat performed very well ran cool oil pressure same exact on both motors, idles mint. hammer down goes on plan much faster than my 242 ss with a 4 blade. I will be replacing the stbd trim motor so I can trim it under full load. it sounds real scratchy....at 62.8 gps and all that weight and basically no stbd drive trim, I should see 65 gps anyway and over 70 on the stock speedo. I like that the stock speedo reads a little high.
