Looking for a potential buy 292/312 >
Old 05-20-2016 | 09:00 AM
Thanks guys, this is what I was looking for. So I guess if I understand correctly, as far as motors for 292 any version is good. Try to locate the hydraulic steering. I really dont see any more options to look for.
what sort of issues can be found with the "The flat cap dizzys on the newer sbc stuff have been known to give issues."
thanks all again
Priobe is offline
Old 05-24-2016 | 09:59 PM
Originally Posted by pondrunner
312 is a much bigger boat than the number implies in person, cabin room, cockpit, hull sides. Go with 502's or 496HO's for power (70ish), with 300hp 454's low 60's top end. 292 is a nice niche' size but small in the cabin especially the v-berth headroom. Look for Scorpion power (77+mph) or 6.2 (72mph), the 350 mag will be under 70mph boat, which is fine, but you won't break 70. Turn the trim-in limiting spacer over to allow the drives to tuck in an additional inch on the 292...slow planning problem solved. I had the 292, buddy has the 312, if I had to do it over, I'd get the 312.
"Turn the trim-in limiting spacer over to allow the drives to tuck in an additional inch on the 292...slow planning problem solved"
I'm not a mechanic, how difficult is it to turn the trim in limiter spacer over? Is there any trade offs that you need to consider before doing this?
netprophet is offline
Old 05-25-2016 | 07:36 AM
its quick. just unbolt both trim ram cylinders from the drive and it will be right there. just flip them around.
Splitdecision271 is offline
Old 05-25-2016 | 10:49 AM
Originally Posted by Mr Maine
The ones I have seen are 2 bolt mains, cast cranks, cast pistons, and powdered metal rods. I have spun the lower ends to 5700 without issue. The 350 mag is 300 horse, the 6.2 is 320 horse. That's what you will find in a 292 fastech, unless you find the more rare 377 scorpion blue motor. Its also a 6.2 but with more horsepower.
Question - Regarding the rarer 377 Scorpion motor, any idea if it has similar service intervals as it's larger brothers, the 500 EFI and 525 EFI? Many folks are doing top-ends on the 500/525's at 300 hours or thereabouts. I know it can depend on how they're used/abused, but just wondering if they are high-maintenance items.
Gary P is offline
