Going to look at a 402 SR1 this weekend, any known weak points ? >
Old 07-15-2016 | 12:03 PM
Default Going to look at a 402 SR1 this weekend, any known weak points ?
The boat has trs drives, but no engines. If I buy it I have 2 new GMPP 502 HO engines to marinize and install in her. Love the looks of this hull but know nothing of their long term durability. Im more of an engine and mechanical guy rather than a fiberglass person. Any common issues with this hull or places to inspect besides the usual soundings and crack inspection?
Thanks,
Rob
robscarab is offline
Old 07-16-2016 | 10:33 AM
Hi Rob, with engines out should be easy to check stringers and transom for any softness. The decks are just screwed to the hulls on the 402's so check to see if it has pulled loose anywhere. Walk along the edge of the deck and check for any sqeeking or movement and at the seam in the engine compartment. Good luck they are great boats. Alot of work but well worth it in the end. Any questions feel free to give me a call
Chris
214 309 8081
chris302 is offline
Old 07-16-2016 | 11:07 AM
Audiofn's Avatar
Charter Member #232
Check the transom and stringers and forward bulkhead very well. Also check around/under the step going down into the cabin. Those are probably the most likely rot points. Depending on the price you are paying you may want to get a pro to take a look with a survey.
Put your best foot forward!
Audiofn is offline
Old 07-16-2016 | 11:22 AM
Thanks guys. I love the look of this model and my only concern is dumping more money than its worth. It looks great in photos and the seller seems like a great guy. I will be leaving shortly to go for a look and will post up some photos tomorrow. Thanks for the tips on what to look for. I've got my fingers crossed !
Old 07-20-2016 | 01:55 PM
Cant seem to post photos here. I uploaded a couple of exterior shots of the 402 to photobucket.
http://s1152.photobucket.com/
Not sure if that works but if it does, has anyone ever seen this boat before?
Old 07-20-2016 | 09:25 PM
Link only takes you to PB homepage.
Need to post links to the pics
rexcramer1 is offline
Old 07-21-2016 | 10:34 AM
http://i1152.photobucket.com/albums/...&1469115098514
http://i1152.photobucket.com/albums/...ps8eoom0do.jpg
Old 07-21-2016 | 12:36 PM
Looks pretty nice, boy that's a long boat though
afratki is offline
Old 07-22-2016 | 07:19 PM
My last girlfriend told me I need to go slower, and size matters....so I bought an old 402!
Old 07-23-2016 | 10:12 AM
Congratulations. If you ever have any questions feel free to call they are great riding boats.
Chris 214 309 8081
chris302 is offline
