1995 Formula Sr1 382 Drain Questions >
Old 04-20-2017 | 04:36 PM
Default 1995 Formula Sr1 382 Drain Questions
On the starboard rear of the boat, under the edge of the swim platform is a series of thru-hull fittings, can someone direct me which one is which, all of mine are disconnected. Should be 4 total
TruxtonFox is offline
Old 04-21-2017 | 07:41 AM
Mentalpause's Avatar
Scupper hose and fitting should be larger. If all the other hoses are sitting there disconnected from the thru hull fittings and are the same size it shouldn't really matter which hose connects to which thru hull fitting.
Mentalpause is offline
Old 04-28-2017 | 08:09 AM
our 2005 has 4 and I cant remember what each is, but they will match up with the hose size. If you have 4, it should be A/C discharge, starboard bilge pump, cabin bilge pump, and shower sump.
PremierPOWER is offline
