Engine stumble overheat? >
Old 07-23-2017 | 07:37 AM
Default Engine stumble overheat?
Yesterday I was able to run full throttle on the bay and hit about 4800 rpm on each motor. It was running super smooth but after a minute or so a warning alarm came on and the boat stumble and slowed som so I slow down. My starboard engine was up around 180ish degrees. Normal is around 165 -170 for me. Could that be hot enough to cAuse an alarm? Or maybe it was something else. I may have trimmed up a bit too much? Could that cause water flow into Bravo 3 to slow or stop?
shekmark is offline
Old 07-23-2017 | 07:39 AM
Not sure if this info shows.
2002 370SS. 496 HO's
shekmark is offline
