292 Fastech Nose Cones, and Props
I have a new to me 292 Fastech with the 377 Scorpions and was going to repaint the drives. I thought about putting nose cones on it while I had them off but was wondering if anyone else had tried them before and with what results. Also curious if there is a benefit with spinning the props in?
Thanks in advance! |
I wasn’t going to respond as I have no experience with a 292, but since no one else s giving you feedback, here goes..
How fast is your boat? I’m not an expert, but I dont think you would see anything good from nosecones on your boat. I dont think they have any positive benefit until you’re over 80 and may have a negative impact if you can’t reach that speed. Generally, props spinning in will suck in the stern (lift the bow) and give you more speed. However, you’re going to lose handling ability around docks. I tried mine turning in. The boat ran better, but it was not worth the loss of manuoverability around the docks to me. Hope this helps. |
Thank you for the reply.
The boat runs right at 80 now with the current set up. I was hoping it would pick up a few MPH with those two changes. |
Originally Posted by soonenough
(Post 4610719)
I would talk to Bblades about your props. If you haven’t had them labbed yet, they can probably
work them to get you a few extra mph. |
| All times are GMT -5. The time now is 11:41 PM. |
