kiekhaefer control cables >
Old 05-01-2018 | 10:13 AM
Default kiekhaefer control cables
Hello I have a stock 1990 SR1 292 with the kiekhaefer controls. I need replacement cables for the bravo drive trim mechanical indicators. Size, length and parts sources? Thank you.
I'm going to modern dash soon, but need to get these in better working condition in the short term.
bigbang is offline
Old 05-02-2018 | 08:08 AM
TomZ's Avatar
The 311 uses 22 and 24 foot cables, starboard and port, respectively. Yours would be two feet shorter.
Give Formula’s tech line a call. They’ll give you exact dimensions. The cables should also be marked along the lengths.
Telefelx makes a replacement that people seems to be happy with. It’s there TFXtreme 3300 series. Around $40 a cable.
Hope this helps!
TomZ is offline
Old 05-02-2018 | 01:07 PM
Not necessarily 2' shorter. The length from the indicator to the drives could easily be the same. The length should on at least one of the cable ends in inches.
The are just 33c cables.
Griff is offline
