-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   86 454 242ls wont start (https://www.offshoreonly.com/forums/formula/354198-86-454-242ls-wont-start.html)
racinjason15 05-27-2018 06:38 PM
hey guys Boat ran like a top all day. Shut if off waiting for people at the ramp. Now it wont start. Could it have gotten to hot? I was running the blower. Checked for fuel. Got that. Its got spark. Vapor locked? Low battery voltage? 180-190 blower was on. It popped started and then died and just cranks.
https://cimg5.ibsrv.net/gimg/www.off...590766f25.jpeg
Redneckcustoms13 05-28-2018 10:09 AM
Did it smell flooded? Sounds like it flooded. That temp seems high. Mine never gets above 150. Not sure what the northern guys run for thermostats but that seems high to me.
racinjason15 05-28-2018 08:17 PM
so it runs great all day but will not restart. I think i have bad fuel. Is the fuel tank accessible? Is it able to be drained? It starts hard too. Long crank. However if i replace the water seperator it starts better. Anything you do if you have a bunch of bad fuel. I ran it to under a quarter tank.
KMONEY306 05-28-2018 08:17 PM
Won't start as in it won't crank? Just clicks? Turns over slow? More info needed
KMONEY306 05-28-2018 08:26 PM
Figures we wrote at the same time! Open the engine hatch basically under the back seat you will see the fuel line coming off the tank and going to the fuel filter. Remove the fitting in the tank and make sure the anti siphon valve is either removed or not stuck. if you have fuel and spark you have a fuel problem or dirty carb etc etc. First run of the year? ****ty fuel clogged up the carb is my best guess. Drain the filter into a clear glass and see if it seperates. Is your distributor tight? Timing could be off if you were messing with it by accident.
racinjason15 05-28-2018 08:31 PM
sorry it cranks and cranks but no start. It has good spark and is getting fuel.
racinjason15 05-28-2018 08:32 PM
[QUOTE=racinjason15;4628816]
sorry it cranks and cranks but no start. It has good spark and is getting fuel. Once i get it running. Usually having to hold it wide open. It runs but i cant shut it off because it will not restart easily.
KMONEY306 05-28-2018 08:41 PM
I'd go with bad fuel. See if it's water related or dirty. If you have the ability to pump out fuel do it. If it's a little water.... swap filters. Put in some sea foam or water remover and a small amount of high octane fuel and run it. To be exact run on a secondary fuel tank and see how it runs not on the boats internal tank
racinjason15 05-28-2018 08:58 PM
ok. I checked the distributor but never turned it. Ill remove the filter and drain for the fuel sample. You may be spot on to the crap fuel clogged the carb. And yes first run of the year.
distantthunder 05-29-2018 02:22 PM
Is it a stock 454?
racinjason15 05-29-2018 11:22 PM
Originally Posted by distantthunder (Post 4628938)
Is it a stock 454?
Stock 454 yes. I am going to pull the water seperator and take a fuel sample and see if its bad. I may try to pull the fuel out. As i have a 30 gallon air powered syphon at work. May go this route.
bbender785 05-30-2018 12:22 PM
does a little shot of ether get it to come alive?
racinjason15 05-30-2018 09:48 PM
negative. I was wondering if you guys think the needle and seat are junk in the stock quadrajet? I have to hold it wide open to get it to start......
Zack_Evans_6.7 06-28-2019 09:32 PM
Good info here. Thanks guys
