Silent choice >
Silent choice
Silent choice
Old 06-16-2018 | 07:18 PM
Default Silent choice
looking at getting the switchable silent choice that just quiets the exhaust at idle or low RPM. I have thru hull exhaust with silent thunder removed, thought it be nice to flip a switch and quiet it down.
problem is I don’t see where the sell it. Corsa says they don’t make it any more, any other companies make this?
Priobe is offline
Old 06-19-2018 | 09:23 AM
Isn’t captains call another version?
Do you still have the y-pipes?
snowrunner is offline
Old 06-19-2018 | 11:45 AM
Never had Y pipes. But was looking for the setup that closes a internal flap to reduce the noise
Priobe is offline
Old 06-19-2018 | 03:50 PM
CORSA Performance Marine
Are you sure they aren't making marine systems anymore?
techman is offline
Old 06-19-2018 | 04:00 PM
They are still making systems but not the thru hull with the switchable flapper w/ solenoid
Priobe is offline
Old 06-19-2018 | 07:18 PM
Veteran: Navy
You're going to have to get Y-Pipe(s) installed for a Captain's Call/Silent Choice.
https://www.perfprotech.com/re-diver...product/242854
AmiableDave is offline
Old 06-20-2018 | 12:24 AM
I have two sets of the external slip on mufflers that close when desired. They use an air pump to close the flap. I have everything needed for complete system. This way no y-pipe needed and easy to install with the same results. Let me know if you’re interested.
Faster Daddy is offline
Old 06-23-2018 | 02:43 PM
When I last talked to Formula and Mercury about this, Silent Choice was no longer being offered as an option (on the 353 at least) and the stated reason was reversion risk. Had mine for 18 years with no reversion damage noted (yet).
wybmabiity is offline
Old 08-09-2018 | 12:25 PM
Priobe... What did you end up doing?
MR.HAPPY is offline
Old 08-14-2019 | 10:08 PM
I'm considering buying a 1995 Fountain Sportfish with Silent Choice. Seems quieter at idle but not so much running. I've owned an Albemarle 24 and a Carolina Classic 28 with exhaust through the out drive. They were much quieter at idle and running. Why isn't the Fountain quieter with exhaust going thru the out drive?
OrionNC is offline
