Water System Issue
Pump runs & runs. It slowly builds up pressure. Get some water out all faucets but won t build pressure & shut off. Flow is good for 4 seconds then runs out of water. I noticed there is no pressure in the accumulator. Is this my problem?
This is on our newly purchased 06 28 ss. |
Originally Posted by drumerjb
(Post 4642804)
Originally Posted by pat@osp
(Post 4642820)
When I first got my 400ss it did pretty much the same thing. Previous owner hadn't used the boat much at all for a couple seasons before I got it. Mine has a filter screen on the inlet (suction) side of the pump. When I first used the boat that screen got plugged up with goop (it was algea or something) coming out of the water tank and blocked water flow into the pump. Pump kept sucking but little to no pressure being created in the system so the pump wouldnt shut off. |
(Post 4642826)
Yes pretty much same situation, system wasn't used much. Yeah I had the suction line off at the pump and filter is okay. But I noticed there is like a anti siphon device in the bottom of the tank that does not allow you to to suck the water up out of the tank.
(Post 4645691)
Plugged the shore power in and with the Charger running the pump ran twice as fast and the problem is solved. So the batterys must have been discharged a little bit. I think I need to replace One battery
| All times are GMT -5. The time now is 07:56 AM. |
