-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   What’s it worth? 1990 242ss (https://www.offshoreonly.com/forums/formula/356305-what%92s-worth-1990-242ss.html)
Skirby12 09-03-2018 08:16 PM
I did. Been out of boating for years but I did flush it. I did that with my last boat too thank you for the advice!!!!! You guys are great and very helpful
oconnor marine 09-04-2018 08:10 AM
Originally Posted by Skirby12 (Post 4647069)
Another update. Took the boat out today. Went down an inlet that has a fast zone. Didn’t want to go too far on the first run. Went well. Made it home. Lol. Have to do plugs and wires and fine tune timing. Had a hard time getting on plane and couldn’t get rpms over 2800 but temp and oil pressure were great. Had a hard time seeing the timing mark but thought I had it at 10 but all in all had a great first trip!!!!! My wife and I went up and down the river for a couple hours. 45 minutes each way out to the ocean. Plugs and wires this week and find a better timing light for the final tune
What prop you have on there?
GLENAMY 242SS 09-04-2018 08:38 AM
2800 rpm? seems more than prop. Did you (engine NOT running) remove flame arrestor, full throttle, and check for the secondary's are wide open?
What did you set as "all in" timing?
ph1971 09-04-2018 11:39 AM
Sounds retarded. They have a nice timing light at Carquest with a tach on the screen so you can do it all from the back. Great to hear that you got it off the trailer. Like Glenamy said look for secondaries to open and for a squirt. Rear bowl may be empty.
GLENAMY 242SS 09-04-2018 12:05 PM
For sure get a light with the digital delay setting and a tach.
Skirby12 09-04-2018 09:50 PM
Hi guys. I believe it’s a 21 pitch mirage. Last numbers are 21. I’m going to put new plugs and fuel filter in hopefully tomorrow and the time it. This tome when I timed it I only had a non advance timing light and the mark was hard to see. Going to paint the mark white as suggested and use a better light. I’m sure it’s probably a timing thing. I’m also gonna by to check the secondaries to make sure they are opened up fully too. I will let you guys know what I find and as always thank you
Skirby12 09-05-2018 06:55 PM
So today I re timed the engine. It’s definitely at 10 degrees at idle now. I’m pretty sure it was way off before now that I could easily see the timing mark this time. Put new plugs and fuel filter in. Couldn’t get a set of wires. Checked the secondaries and they are open all the way. Still couldn’t get my hands on an Advance timing light but it’s running good. Have to put in the water again and test it. But hopefully I can get my hands on another timing light to set advance timing. Trying to get it ready for a decent length trip on Saturday.
Skirby12 09-07-2018 08:59 PM
So I took the boat out this afternoon and wow what a difference. Revved right up. Got right up on plane. Speedo doesn’t work but putting a chart plotter on tomorrow morning before a day trip so will update with gps speed. Thanks everyone for all the help and advice!!!!!!!! Glad the work paid off and got it going good. Couldn’t have done it without all the great advice on this forum!!!!!! Thanks again!!!!
oconnor marine 09-10-2018 10:54 AM
On a good day she should break 50 mph. Have fun
Skirby12 09-10-2018 12:38 PM
Thanks O’Connor. It was rough on Saturday so didn’t get to open it up but seems like I’m only getting about 3500 rpms. I believe the prop is a 21 pitch mirage. I was only able to base time the engine as I couldn’t get an advance timing light. I also changed the ignition module from a v8-24 to a v8-22 as that was all I could find at the moment. I’m sure that’s all playing into it and will keep trying. It’s getting better each trip
