Formula bolster seats needed >
Old 03-07-2019 | 06:17 PM
Question Formula bolster seats needed
i have a 1988 F242SS looking to change to bolster seats (driver and passenger​​​​​)
they don’t have to be in great condition as I’m going to have reupholstered. Thanks
F242ss is offline
Old 03-08-2019 | 05:46 AM
I had that same year and model. What color?
oconnor marine is offline
Old 03-08-2019 | 02:12 PM
TomZ's Avatar
Good luck finding them. You may want to check out the Formula SR1 group on Facebook.
On a side note the 242 SS was a sit-down boat while the 242 LS had the option of bolsters. Attaching points were installed in some 242 LS boats so that bolsters could be added. I don't think this was a consideration on the 242 SS. The bolsters are thru-bolted to a bracket under the floor; you'll need to duplicate this to properly attached the bolters. You don't want them lag-bolted. The attaching point will be above the gas tank into the removable part of the floor.
If you need the legs or the side brackets, I may consider selling the spares that I have for my 311.
TZ
TomZ is offline
Old 03-08-2019 | 02:50 PM
Glanamy242 put bolsters in his 86 242ss. It required some modification because of the deck locker. Might hit him up for pictures of his install. Good luck. Good boat.
ph1971 is offline
Old 03-08-2019 | 08:50 PM
It’s white,teal,gray and black
F242ss is offline
Old 05-03-2023 | 03:35 AM
Is it possible to install adjustable heights seat posts instead of going the bolster route?
NorCalNomad is offline
Old 05-03-2023 | 07:30 AM
TomZ's Avatar
Really depends on what you’re trying to accomplish so try the boat. An offshore boat running in bigger water will be more comfortable and safer feeling with bolsters. You can probably get bolstered seats to sit on a pedestal, but you won’t be able to stand within the confines of the bolster (typical for rough water running).
Sit-down seating is an option, too, but to do it right can get really expensive.
TomZ is offline
Old 06-15-2023 | 06:57 PM
Default Bolster seats
I have a set out of a 99 353 I would sell if they would work for you.
99Fastech353 is offline
Old 07-30-2024 | 06:17 AM
hello...do you still have the bolster seats..??Thanks,Bob
bbadboybob1962 is offline
Old 07-30-2024 | 06:33 AM
no sorry they were sold
