What weight 1988 Formula 311 >
Old 06-09-2019 | 12:49 AM
Default What weight 1988 Formula 311
I just bought a 1988 Formula 311. I think the brochure shows 7400 lb. It's got Big Blocks and a steel Manning trailer. With a hundred and fifty gallons worth of gas in 15 gallons of water what's my total gross weight? I'm trying to figure out what kind of truck I need at a minimum to be safe and legal to drive this boat. Thank you
F14A water jet is offline
Old 06-09-2019 | 09:29 AM
At minimum a 3/4 ton but I'd go ahead and get a dually. Any of the modern f250, duramax, Cummins trucks can handle that boat. I have friends that fish with us towing 31 contenders with 6.2 gas burner Yukons. It works just drinks a ton of fuel. I'd reach for a 6.7 Cummins if it were me and the budget allowed.
Redneckcustoms13 is offline
Old 06-09-2019 | 10:31 AM
97FASTech's Avatar
Veteran: Army
gal water = 8.3 lbs 15 x 8.3 = 124.5 lbs
gal gas = 6.1 lbs 150 x 6.1 = 915 lbs
add in gear, food coolers = 400 lbs
7400 + 124.5 + 915 + 400 =8839.5
Some one would have to help figure difference between small block and big block weights. But looks easily at about 9500 lbs on a conservative guess. Now add in the trailer weight. looks like maybe 11,500 - 12,000.
Sound reasonable?
97FASTech is offline
Old 06-10-2019 | 06:38 AM
Any 3/4 ton truck will work just fine
kevlar382 is offline
Old 06-10-2019 | 08:46 AM
My 303 weighed 10,200 on an aluminum trailer so you'll probably be around 11,500+.
Any 3/4 ton will be just fine.
Having said that, the guy that just bought my 303 towed it home with a newer F150 with factory air ride and he said it did just fine.
payuppsucker is offline
Old 06-10-2019 | 10:14 AM
I want to try to be safe but also legal in case I get into an incident. So I'm estimating 11.5 to 12000.
Old 06-10-2019 | 10:41 AM
Why not tow to a truck stop and weigh it on the CAT scales. 1st weigh is $11.00 and additional weighs on same day is $ 2.00 each.
GLENAMY 242SS is offline
Old 06-10-2019 | 10:54 AM
I will probably just do that. I just assumed on this floor that would be enough information on like boats.
thanks to all, Tom
Old 06-10-2019 | 11:21 AM
Like everyone is saying a 3/4 ton will handle it. I've been towing heavy long distance for over 13 years now. I love a 3/4 ton dodge with a 5.9. But once I got settled in a dually I love it. So much more stable. Less tire fatigue. So many winning factors.
Being as you will probably need this vehicle for daily commute and towing your boat, a single rear wheel may be best.
Old 06-11-2019 | 10:30 AM
In later years formula revised the dry weight to 8k. Figure 2k in fuel, water, gear etc. 2k for steel or 1500 for aluminum trailer. 11500 on an aluminum trailer is a pretty good estimate.
Mr Maine is offline
