-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Perko and Charging 1988 F311 batteries (https://www.offshoreonly.com/forums/formula/361468-perko-charging-1988-f311-batteries.html)
F14A water jet 06-26-2019 06:40 AM
Kinda reviving an old thread...
Charging 1988 F311 batteriesQuote:
Originally Posted by 86242ls https://www.offshoreonly.com/forums/...s/viewpost.gif
It will charge as long as it's plugged in thru shore power and you have the breaker switched on in the cabin for the charger. It will charge if the perko switch is on or off You probably have a guest charger from the factory its a 15 amp charger ten amps to one battery and 5 amps to the other. I swapped mine out for a newer unit that is a true 10 amp per side charger.
Is this Perko switch location and information good/right for a 1988 F311?
Thanks,
Tom
Smoke eater 06-26-2019 09:21 AM
This is how mine functions on my 1989 272 Sr1. I know its not the exact same boat, but I would think it would be the same across the board.
TomZ 06-26-2019 11:17 AM
The Perko switch is the battery selector switch (Perko or Guest). It is independent of the battery charger.
TZ
F14A water jet 06-26-2019 12:50 PM
TZ
1) So, by independent, do you mean that the batteries will charge with shore power plugged in NO MATTER WHERE THE batery selector switch is positioned?
2) Will it work to just get an adapter plug/extension cord from Home Depot and just plug the NEMA L5-30 it into the garage 120V circuit to keep the batteries topped off?
or
3) Do you guys use normal trickle charges/battery tenders for purpose #2 above?
4) Is there supposed to be an "Owners Manual" with all these kinds of answers in it?
Obviously a NEWBIE here!
Tom
https://cimg7.ibsrv.net/gimg/www.off...8a6adc470f.jpg
TomZ 06-26-2019 02:50 PM
1. Yep (if it’s wired correctly).
2. You can pick up an adapter for the cord from West Marine or Amazon. This one is from West Marine... I’m sure you can find it cheaper:
https://www.westmarine.com/buy/marin...40?recordNum=3
3. I use the adapter above and keep my shore power plugged into the house electricity. No need for a trickle charger as the onboard charger does that for you. You more than likely have a newer charger.... I know mine was replaced at some point and they do not last forever. It should be fairly smart.
4. My 311 (and my old 242) came with all this information in a binder provided by Formula. You may have it in the boat somewhere. But do ask questions any time you want! This place can teach you a lot!
The boat looks great in that garage!!
F14A water jet 06-26-2019 05:14 PM
Thanks! I live "in town" (Madison, North Carolina is just like fictional Mayberry) with no additional space for the boat...so I have leased space which is 2/3 below grade (significantly cooler), well lit, and has is dehumidified.
Now I am ticking of the little "to dos" the boat needs. Therefore, stand-by for more questions! :-)
ph1971 06-26-2019 06:00 PM
I wish my biggest concerns after buying my boat were chargers and anchors. You have obviously made a good purchase. Sharp looking boat. This Formula group is a great bunch, but beware of the 242 guys, none of em are playing with a full deck.Happy boating.
F14A water jet 06-26-2019 07:52 PM
Frankly, I paid 50% more than the lowest priced 311/292 that I was looking at...but this boat was in the best shape and had all the upgrades that I would have probably done anyway over the next 3-5 years. So far, so good...now if I could just figure out why my Tekonsha Prodigy P2 is not actuating my Hydrastar EOH hydraulic brakes on my trailer???
The trailer worked with a new RAM truck and I'm getting voltage to the Hydrastar but so far no luck (I am talking with Hydrastar as we speak).
GLENAMY 242SS 06-27-2019 09:14 AM
Just because we play poker with a Penuckle deck doesn't mean it's not a full one.
Nice looking boat. Congrats on the acquisition.
F14A water jet 10-30-2019 03:32 PM
Where is this circuit breaker located?
