New Engines for a 292 Fastech >
Old 06-30-2019 | 04:24 PM
Default New Engines for a 292 Fastech
Well, since I will be tearing the boat apart this offseason to have the the transom rebuilt, I'm gonna build new engines. I plan on building brand new 400 small blocks and selling the stock 350 mags minus belt drive and plumbing. Engines will be 100% brand new minus the IMCO exhaust. Who here has done complete swaps in a 292? Any tips or advice? Any input is appreciated!
Franks292 is offline
Old 06-30-2019 | 10:52 PM
One piece of advise...if you have any inclinations to get a bigger boat, don’t throw money away. If your convinced you will have it for the next decade...that’s another story. Good luck!!!
1MOSES1 is offline
Old 07-01-2019 | 08:40 PM
I do eventually but simply cant afford to spend the extra 40-50k on a bigger boat with all of my other hobbies.
Old 07-01-2019 | 10:30 PM
SB
What heads, induction, compression, exhaust specifics, and max rpm you are comfortable running.
SB is offline
Old 07-02-2019 | 07:56 AM
I've always wanted to see someone utilize the SBC/LS hybrid blocks in a 292. Basically all sbc bottom end with LS cylinder heads and induction, they are such an effecient chamber. I know you aren't going this way but every time I see those blocks I think "Man wouldn't those be awesome in a 292!"
TylerBurich is offline
Old 07-02-2019 | 08:27 AM
Knot 4 Me's Avatar
https://www.mercruiserparts.com/383-mag-stroker-mpi
Knot 4 Me is offline
Old 07-02-2019 | 09:41 AM
I was looking at AFR heads with 195 intake runners, comp XM276HR cam, edelbrock performer rpm intakes with quick fuel 850 double pumpers, 9:1 compression to be on the safe side, imco powerflow exhaust, and 6000 rpm would be max.
Old 07-03-2019 | 07:25 AM
I'm going through this now myself. Long story short, head rotted out, water on top of cylinder, bent a rod, replacing both engines.
Had under 300 hours on them but time and corrosion just caught up to me. I looked at going with 377 Stoker long blocks but the added cost of getting those blocks along with having to reflash the computers just didn't seem economical or fit the budget. Ended up just replacing exactly what I had in there with new, not remanufactured, GM marine 350 long blocks. Swapped everything else over from the other motor. Also added full closed cooling, so hopefully no more corrosion. Upgraded exhaust to Hardin Seaward manifolds with stainless risers. Got 17 years out of the engines boat came with, this setup should last just as long if not longer.
Splitdecision271 is offline
Old 07-05-2019 | 05:18 PM
Dang! Keep us posted. I have a 292 with 350s as well!
SabrToothSqrl is offline
