Merc 350 MPI - No Start. 2001 >
Old 10-08-2019 | 07:23 AM
Default Merc 350 MPI - No Start. 2001
I had difficulty starting my starboard engine when hot, so I replaced the Idle Air Control. (as it was easier to start with just a little throttle, I suspected the IAC).
Ever since it's become a no start condition. I even replaced the IAC with the original 20 year old one, with no luck.
The engine ran all season, ran when shut off a week ago, and hasn't been able to be started since. I've tried everything I can think of.
I replaced the fuel filter, it has plenty of fuel. I pulled the gas line going to the fuel rail, and the fuel pump is definitely working.
I put a spark plug tester on and it's getting spark to all 8. the rotor in the distributor is spinning.
I tried starting fluid - no dice. I checked for DTCs. There are no stored codes. Manual says the MAF sensor can cause a no start and to disconnect it - no dice. I even tried disconnecting the IAC and TPS. No dice.
The engine ran at shutdown. Then never again. What am I missing? Fuel, Air, Spark?!
Thanks!
SabrToothSqrl is offline
Old 10-08-2019 | 07:58 AM
Was spark tester used on all 8 or just the coil wire?
Are you seeing the tach increase to at least 300 rpm while cranking?
What is the fuel pressure at the rail?
AllDodge is offline
Old 10-08-2019 | 09:42 AM
I was slightly lazy, I tested 3 of the spark plugs with the tester. the coil wire has enough juice to make my left arm numb! bright blue spark jumped.
Cranking speed seems good/normal. I didn't check on the tach, but the battery is also plugged into a charger/starter, so I don't think it's low on juice.
I didn't check fuel pressure, is there a connector to plug into somewhere? I just removed the line going to the rail, turned the key to run and when the pump ran for 2 sec it dumped a lot of fuel out... I know, stupid, but pump at least pumps fuel.
Could it be the fuel pump? Maybe. But should it not have at least tried to start when I was dumping starting fluid down the throttle? The starting fluid didn't make any difference at all. And that stuff is flammable!
How would I attach the fuel pressure tester? Does the harbor freight one fit?
Did I somehow accidentally rotate the distributor while removing the IAC? How far off would it have to be, for a no-start? Setting the timing is done with an engine running... I can't even get that.
Thanks for your help! I feel like I'm missing something so basic/small. And who the hell uses distributors? My 1990 OMC 460 was smarter than this 2001 Merc...
Old 10-08-2019 | 10:40 AM
Unhook the line that goes from the pump to the fuel rail, and hook it into this thing?
https://www.harborfreight.com/Fuel-I...ter-62623.html
manual says it should read 30PSI.
Old 10-08-2019 | 11:31 AM
Looked up 2001 (no serial number listed) and you have
EDIT - you did say MPI
check the tach and see if its moving up to 300 rpm or above. Looking at the tach lets you know if its spinning fast enough and more so lets you know the distributor is pulsing. No tach signal no fuel pulse
AllDodge is offline
Old 10-08-2019 | 11:45 AM
I needs a serial number
AllDodge is offline
Old 10-08-2019 | 11:48 AM
Thanks!
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAALsAAAAfCAYAAAC/HbySAAADM0lEQVR4nO2azbWtIAyFrSsFUQ/VUIkziskbKCCYAFHPHTz2XovJOeEn8gkxsO37zigoK5Rt33eGo P9dgB1aRoAdWkaAHVpGgB1aRoAdWkaAHVpGgB1aRkPYY3BMtPG 2nYWIXYiCZWCXbDZiL5ncqjimVMeFl/0L40n1yHPdemR/bVMp1DoRA3tHtY3zLA4n+uKbUBR3X/gLjdSFPeSJJXbOsbtM9A2ECnYd3qIGOMHe1n/Tur9C6bhtPXh3tikUEvoI7gL4YUed9jPsJPch8fvGX2gsHfY0u eS5esx5xWpX7xN2SrAIAAjtU4Kmhd3cv2Dj3PkCDsZSVz5fwrr 96InJhXoslxf2vgscY5iG9I2/0JRU2IPTt9v0Xz2RCXbP4VxVexN9tEHsgxdht/cvtB2DHfYE3XBnOpR3kNbeCPsbf6E5KbAPIBGBKLDHvIU3q1RS vAAeJdif9F+3fYBhh70HneyK8mKbYH/hLzStPuwjWKv/6zpldZWqUwGqB7upf+YSViRojLCPXlLNXvJTitm95xA7H/dmfyGLZNhnV+YO7PpqdAKZ7CTYH/Vf+iyrqQ32YbgQw+0jdiMnx9K9bAw143nqL2TS72DXQGuB/Az25iXqjUHUhO0lI1MKsVNfjmbfiXU6NP8L2P9EP4S9CVeSVRv efAX7CWK9kczDrn5o9upczgloul4ak/AMAPtP9Q72UZzdttMD+wnsuY4W887CLqcbp2RODZZ0ZR7+o+cN WfWbbEz+rYZIWuk/ycak0Oh2gEMZxOMgqM2TN+09WjkFeM32yMb8hRTY+xMop+fk1b Wk5rw8oSLstv7r09JekWGyphub2vewxGz/5HlDVqmHShkg9USvBWcUSiiZDmWLtvcvaSKMmWovslfuqMjjjO wdsb/Zxwzub/yFeurcjbneXWnvapCwyui54jzBvXy0lqKc7l/SGPa508l6LPluDGl+XeyJmpBKSD1+5i/U0+DWY+RwnaQzLpYv4XUORiZOPOV41NJ/Z0wq7JYQJHLwzY3EjTq3Hu9j34jYeeW74RN/oZ5wnx1aRoAdWkaAHVpGgB1aRoAdWkaAHVpGGXYUlBXKP68UhB D//nVQAAAAAElFTkSuQmCC[/img]
I will check the tach tonight.
Old 10-08-2019 | 11:49 AM
I tried to paste the serial number from excel... whatever that mess above is... sorry.
0M047350
thanks!
MFI-3
Old 10-08-2019 | 12:01 PM
Remove cap (item 7) and attached gauge to shrader valve (item 6)
https://www.mercruiserparts.com/bam/...31745/2691/110
To post pics, select the button which looks like mountains
AllDodge is offline
Old 10-08-2019 | 12:58 PM
Default Fuel pressure
Thanks.
Mine have the hard lines between them like this.
https://www.marineengine.com/parts/m...067N1/4848_120
but the parts are the same.
I guess I’ll pickup a fuel pressure gauge on the way home.
thanks!
