Charging dual batteries
Hi,
Being a new owner of a 1987 Formula 242 ls, I'm looking for some information on the right way to charge dual batteries from shore with a Perko switch. Should I select one battery at a time or will selecting "all" charge both batteries but at a slower rate.
Again, my thanks for any information
Tony S
Tony S
Single engine I will assume.
Putting the switch to "all" will charge and discharge the batteries as if they one large battery. Depending on your alternator capacity and current battery conditions it could take a long time to adequately charge the batteries in this configuration, unless you are running your motor all day long with little or no load from accessories. I like to keep one battery as fully charged as possible...just in case you need it. Using the "all" setting gives you no backup.
Some options are to alternate days. One day use battery one and the next time out switch to battery two. That way you are keeping one charging and one offline. Or another option is you can switch to battery one on your way out for the day and switch to battery two on your way back in. Again, your mileage may vary on length of running time and how much drain from accessories you use.
Best to start with a good external charger and top them off to get a base level. Charge them separately.
Hi,
Tony S
Tony S
Hi,
Tony S
Tony S
I have a NOCO Genius 20 amp 2 bank charger permanently mounted in my boat and keep the boat plugged in at all times. Currently have 5 years on the batteries and still going strong. Whichever charger you choose, make sure it has a tending mode.
A few good options posted above. I'll add my 2 pennies as well. I have 2 individual chargers in mine. Previous owner installed. A few days before using the boat I'll plug them in. Verify voltage while checking oil and what not. I always place the perko on both. Run the boat to the desired hangout. Switch to batt 1 for stereo purposes all day. When preparing to leave I swap back to both. On the way in this will charge both batteries. Because the alternator is charging obviously, but also because the unused battery is now in parallel with the weaker one. They will balance out over a short period of time.
