Lowrance 3500 depth finder replacement? >
Old 05-29-2020 | 04:49 AM
Default Lowrance 3500 depth finder replacement?
Looking for recommendations on new unit to replace my old Lowrance 3500. I'd like similar size and style as keeping it in existing location. Also, since old transducer can't be used or reached without cutting boat apart Formula support suggested putting new thru hull sending unit under cabin step. Any suggestions appreciated!
Joe308 is offline
Old 05-30-2020 | 08:47 AM
97FASTech's Avatar
Veteran: Army
There is this:
Amazon Amazon
97FASTech is offline
Old 06-22-2020 | 11:18 AM
Joe308,
What model boat do you have? I am adding a Garmin GPS with shoot through transducer, under the step would be easy install.
I have a Fastech 312.
Priobe is offline
Old 06-22-2020 | 02:28 PM
TomZ's Avatar
Responded in your other thread, Josh.
In the parts diagram for the 420 and 425, there are different risers options. It would be interesting to see what the inside of the tailpipe looks like (Merc refers to it as a tailpipe). I'm voting muffler especially since she seems to sound like a Sea Ray in the videos I've watched.
TomZ is offline
Old 06-23-2020 | 06:08 AM
Originally Posted by Priobe
Joe308,
I have a 353 and the choices are somewhat Limited for 3 1/8 in units. Most are big screen now. Ended up going with the Lowrance 3800 and I will be epoxying the skimmer transducer into the same spot under my step where the puck transducer was. It was very difficult to get the original one out but after much prying and banging we finally did. I spoke to Lowrance about this and they said the transducer would work as a shoot thru just with a liittle reduced sensitivity. There are also some videos online.
Joe308 is offline
