F311 SR-1 Remote Drivelube Reservoir >
Old 08-25-2020 | 06:04 PM
Default F311 SR-1 Remote Drivelube Reservoir
I do not know if my 1988 big block formula 311 has remote Drive Lube reservoirs (Bravo 1 drives). Can anybody tell me where they might be located and maybe send a picture of what it might look like? I'm going to change the fluid in my bravo ones and want to include the reservoir if necessary.
thank you
F14A water jet is offline
Old 08-25-2020 | 06:21 PM
1988 did not use reservoirs
Unlimited jd is offline
Old 08-25-2020 | 08:14 PM
so just fill the unit as normal. Do you have a recommended brand / style a drive oil?
Old 09-11-2020 | 01:54 PM
TomZ's Avatar
Remember to fill from the bottom.
I've always used Quicksilver High Performance Gear Lube. Walmart has it pretty cheap. It is usually kept with the boating and fishing supplies (not with engine oils in the automotive section... though they do keep the standard gear lube there, go figure).
TomZ is offline
Old 09-27-2020 | 06:18 PM
offthefront's Avatar
You could add the resovores... I think there is a kit ..
offthefront is offline
Old 09-27-2020 | 06:24 PM
Thanks, I will consider it after I resolve the issues from Hurricane Sally.
Old 09-27-2020 | 06:43 PM
TomZ's Avatar
If the transom assemblies and drives are older, there isn’t a provision to add these. My ‘89 had them but my buddy’s ‘88 Cigarette does not.
TomZ is offline
Old 09-27-2020 | 06:54 PM
does this mean your making the repairs!?!!?
Smoke eater is offline
Old 09-28-2020 | 08:13 AM
Not necessarily. I am preparing for either eventuality rebuild or replace. Additionally, this experience is allowing / forcing me to learn more about these boats.
