2001 White Rocker Switches >
Old 09-14-2020 | 09:07 AM
Default 2001 White Rocker Switches
Anyone know where I can get this switch? I'd rather not redo a bunch of these to make them all match if I don't have to. I have a repair list a mile long already.
thanks
https://www.youtube.com/watch?v=_7rV...ature=youtu.be
SabrToothSqrl is offline
Old 09-15-2020 | 09:37 AM
TomZ's Avatar
Try searching on Great Lakes Skipper. Or you can reach out to Mike Mello (Sick Stinger). He’ll probably have something.
TomZ is offline
Old 09-22-2020 | 09:26 AM
I emailed Great Lakes - no dice. The 'shaft' on the back is what broke. I superglued the F out of it, fingers crossed for now...
Old 10-07-2020 | 12:57 PM
I was able to replace mine using these part #1TP201-7. They are a white/clearish switch cover but they work. I did have to open up the hole a but on teh back side, no biggie, to slide down the stud on the back of the panel.
I ordered these through Arrow Electronics using part number 1TP201-7 paying $28 each. Much cheaper than the ones formula used by Rockwell, that hoesntly are garbage, as I had already replaced them prior using the OE part number from Honeywell part # 2TP8-7.
Hopefully this helps.
gsxrmike is offline
Old 10-08-2020 | 07:40 AM
Cool, thank you
https://www.verical.com/pd/honeywell...SABEgJNH_D_BwE
I superglued it for now, and it's holding, but who knows how long that will last. Fingers crossed it's 10 years.
Old 10-08-2020 | 09:23 AM
livorsi has them
Livorsi Marine, Inc. - Military Toggle Switches, Rocker Switches, Circuit Breaker Toggle Switches, Push Button Switches
30outlaw is offline
Old 01-13-2021 | 12:22 PM
ericaull's Avatar
They are now available in BLACK only.
ericaull is offline
Old 01-13-2021 | 12:36 PM
"Military Rocker Switches" - thanks! I like how I can't just click it to buy it like it's 1988 or something...
red would look cool, if available.
if it breaks again, I now have a lead. Thank you.
