252br 7.4l surging/ tug over 3k rpm
Ok so i had what i thought was a misfire, found cylinder 5 low on compression, redid the topend, valvejob, headgaskets ect…. I put a new edlebroke(lol) 750 1410 carb on it. It still tuggs and surges and sometimes wants to die. Im at a loss with tuning. I have changed springs, took the metering rods out…lol still does it. Anyone had this. Ive also replaced coil, and verified timing 12dbtdc. Start normal idles run normal, I will do it above 3000 RPM. And sometimes it acts like it’s lean. Im at a loss. Any help would be appreciated.
Carb should be 8* BTDC
Does the motor have a flat tappet or roller cam? |
Fuel psi stay at 5psi or more ?
Which distributor set up ? How many hrs on everything ? |
Originally Posted by AllDodge
(Post 4843280)
Originally Posted by SB
(Post 4843295)
Originally Posted by racinjason15
(Post 4843551)
Oem, hei distributer, top end has maybe 5 hours, i had the heads machined, valvejob, all new topend. Im goin to have to get a gauge and check fuel pressure… whats the best way with the hardline set up to the carb?
I have flared to nipple fittings and use rubber line for the test. So, undo steel line and install that. 3/8” inverted flare (mine are swivel) by 3/8” id hose bard fits many fittings on mech fuel pumps and fittings on inlet of carb. Obviously get a 3/8” hose fuel psi gauge adapter and 1/8” npt psi gauge. That’s how my set up is, surely other ways. https://cimg4.ibsrv.net/gimg/www.off...abda7d917.jpeg https://cimg0.ibsrv.net/gimg/www.off...f50e0ecb7.jpeg |
(Post 4843550)
flat tappet. .
zero lash - push rod is being moved up-and-down until no up or down movement is felt with fingers. The push rod can still be rotated but there is no up/down |
| All times are GMT -5. The time now is 07:57 PM. |
