-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Formula 272 SR1 vs Pantera 28 (https://www.offshoreonly.com/forums/formula/379193-formula-272-sr1-vs-pantera-28-a.html)
Scarab Viking 05-09-2023 04:36 AM
Most people would probably say that the Pantera is probably a bit better in the rough, but is there a huge difference? I'm looking at two boats for sale and the Formula is half the asking price of the Pantera. Just wondering if the Pantera is worth twice as much?
I value rough water handling most of all, and I know there are plenty of other boats that would be good too, just wondering about the difference between these two particular models, so how is the structural integrity of the 272? I know some old boats have rotten transoms and stringers, but that's a generic problem for all boats built using wood (which is not all bad although it requires good maintenance), but other than that? Will it handle the same amount of punishing pounding in rough seas, and if so - will it keep up at the same speed as the Pantera?
TomZ 05-09-2023 09:15 AM
I responded to your question in the General Discussion forum.
Post up the boats and we’ll be able to dig a little deeper.
More than likely, Pantera is what you’re going to want.
Sonic24 05-09-2023 10:54 AM
Formula 272's do well in the rough...
https://cimg4.ibsrv.net/gimg/www.off...a310fa4530.jpg
TomZ 05-09-2023 11:04 AM
Just in case some may be reading that I don’t think a 272 is a good rough water boat…
Everyone here pretty much knows me as being loyal to Formula. My thoughts are that the 272 is more than capable in rough water to a point.
With that said… the OP asked for a comparison to a similar-sized Pantera with an overall emphasis on rough water usage hence my vote for the Pantera.
Scarab Viking 05-09-2023 11:15 AM
I'll skip the pictures, since the boats look like any other Pantera 28 and Formula 272. The remaining facts might be of interest though:
They are both single engine BB boats, with approximately 550 HP mated to Bravo outdrives. (Yes; the Fornula has been converted to a single engine boat.)
As far as flying through the rough, I know most Pantera racers have preferred single engine setups to fly more level...)
What do you think?
TomZ 05-09-2023 12:00 PM
The 272 has always been a twin engine boat. Are you sure you’re not looking at a 271?
TomZ 05-09-2023 01:20 PM
I think there was a guy over in the UK (or may it was Australia) that converted a Volvo powered 272 to a single BB. Not sure how it ran, but I don't think it ran well. It's a heavy boat for a single engine even with 550 HP - That's maybe a tad more than the twin 350s it would have came with but instead only doing it with one wheel vs two. I don't see the advantage there. And that doesn't included the structural issues that come from removing the center stringer that helps tie everything together in the stern. Not sure I'd even consider it.
Where's the Formula located?
And pictures are always great!!
Scarab Viking 05-09-2023 04:43 PM
The Pantera should be just as heavy, and most people consider the single engine Panteras to run better than the tail heavy twin engine boats, so the Formula should run well with a single BB too, right?
TwinAfter all, both hulls are about the same size and weight.Twin stringers probably do a better job of connecting everything with the transom than a single center stringer - especially since they can form an ongoing continuation of the twin stringers that already run almost the entire length of thr boat - all through the cabin, underneath the cockpit and onto the bulkhead in front of the engine compartment. That is - of course- if done correctly, which is quite an extensive job. Here are two pictures of the British boat, converted to a single engine:
https://cimg6.ibsrv.net/gimg/www.off...3c3c6aad22.jpg
https://cimg7.ibsrv.net/gimg/www.off...1c7ad9e837.jpg
Scarab Viking 05-09-2023 04:46 PM
100% Sure:
https://cimg1.ibsrv.net/gimg/www.off...8d22558869.jpg
https://cimg2.ibsrv.net/gimg/www.off...51473e305f.jpg
https://cimg3.ibsrv.net/gimg/www.off...a8bd71c46e.jpg
https://cimg4.ibsrv.net/gimg/www.off...8da86540f7.jpg
TomZ 05-09-2023 07:39 PM
One of those looks like it maybe a 292.
I wouldn’t consider these as being good alternatives to the Pantera.
The Formula is a very heavy boat for its size; the weights listed by Formula did not include fuel, oil, water, and gear.
Take the 311 for instance - it’s advertised as weighing 7400 lbs - not even close! They weigh about 2k-2.5k lbs more ready to run. And that doesn’t include the water that they’ve probably soaked up over the years either. 9500-10k lbs is probably more realistic. The 272 isn’t much lighter and a 292 is just a couple hundred pounds off. I think the 272 comes in around 8k lbs - remove a drive package and you’re at 7k lbs.
A single engine Pantera 28 weighs in at just under 6k lbs with fuel per owner comments here on OSO.
Scarab Viking 05-09-2023 11:13 PM
Interesting reply! Thanks for your input! I guess another argument for the Pantera is the way they joined the deck and hull: They are fiberglassed together, right? I guess the Formulas are just screwed together? Can anyone confirm this suspicion? :)
Scarab Viking 05-09-2023 11:14 PM
Both Formulas above are 272s
TomZ 05-10-2023 07:11 AM
Yep, my understanding is that the Pantera is fully glassed. The Formula is thru-bolted using backing plates a bonding agent named Arogrip (similar to Plexus adhesives I’d imagine).
Jerker 02-05-2026 05:24 AM
Formula 272
the yellow and Grey White formula was my old boat and I coverted it from twin engine to single engine in 2011 it ran 56 knots with 550 hp 😀
Jerker 02-05-2026 05:28 AM
https://cimg1.ibsrv.net/gimg/www.off...d72a0be4d1.jpg
https://cimg2.ibsrv.net/gimg/www.off...3976c027bf.jpg
https://cimg3.ibsrv.net/gimg/www.off...ca2a5e1779.jpg
Scarab Viking 02-06-2026 03:32 AM
Thanks for your input Jerker!
It looks like you did a good job! I really like the looks of the boat! It certainly isn't the fastest rig out there for it's size, and maybe not the most durable either when it comes to taking a beating in the rough, but I figure that rebuilding s few more things (like glassing the deck to the hull, etc) would make it a tank for its size. Heavy weight is a good thing in the rough, and this model also has a lot of space in it for a 27' boat.
Full Force 04-23-2026 11:52 AM
Not even close to a comparison, the Pantera is 100% a more rigid and quality build, Pantera all day long will out perform even a 357 in ride quality and the slamming the formal will do, they all do the job, but how the boat holds up is the difference and how many times you say ouch
