Looking for info on Formula 242 LS >
Old 05-28-2024 | 07:07 PM
Default Looking for info on Formula 242 LS
Hi all, looking at a couple 242 ls's and I know nothing about these boats..
One is an '87, the other a '90..300 (rebuilt) and 700 hours respectively. Both appear to be in really nice condition and are priced at 22k and 25k respectively which seems high to me for an older boat, but I'm not sure how well these have held their value over the years or if they're considered a modern classic and may be appreciating a bit if in nice condition, etc.
Would appreciate any insight from folks that know these boats.. Common problems, current values, etc.
Thanks!
cshults is offline
Old 05-28-2024 | 07:27 PM
jeff32's Avatar
well...
as for any boat, any year, unless it is new....
survey survey survey !
of course quick mecanical inspection. but make sure you don't buy yourself a lot of work instead of a boat!
good luck in your chase !
jeff32 is offline
Old 05-29-2024 | 08:13 AM
masi242's Avatar
The 242 is a great boat, but those prices do seem a little high i would think mid teens would be reasonable. Unless it was mint any of these have bolsters or just the captain chairs, what engine small block or bbc and what kind of trailer? Also what drive i assume the 87 would be the alpha, and the 90 is a Bravo.
masi242 is offline
Old 05-29-2024 | 01:17 PM
Thanks for the reply. I would say both appear to be in above average condition and not in need of anything major cosmetically.
Both have pedestal captains chairs and the 454 Magnum and yes, the 90 is a bravo. The 90 also has a newer loadrite trailer and the 87 has an aluminum tandem with new brake lines and tires.
​​​​That said, I figured either of them would fetch between 13-17k.. But if they are as good as the ads made them look I wouldn't mind paying a bit of a premium, but not a 5-10k premium but do understand that some boats (or any rec vehicle for that matter) do command a higher sales price if they're a sought after, modern classic - just unaware if these boats are that.
cshults is offline
Old 06-10-2024 | 04:44 PM
TomZ's Avatar
The 1987 unless it was repowered would have a Alpha One for a drive and the stock engine would be a low-perf 454 "Magnum" with cast internals - not something to really be beat on. Unless the '87 has been repowered with a Bravo I wouldn't even consider it - the boat is too heavy and even the low-perf 454 has enough torque to break it pretty easily. The 1990 with the Bravo would be the one to have.
At this age most of these boats will suffer from some kind rot in the transom as well as the bulkheads around the engine so make sure you're looking closely.
TomZ is offline
Old 06-10-2024 | 04:45 PM
TomZ's Avatar
Also, those prices are ridiculous.
TomZ is offline
Old 07-17-2024 | 09:58 AM
Survey, go with a Bravo on a big block.
Prices do seem high, I got mine in Oct at the end of the boating season and am in it totally about 12k in slightly above average condition with a clean survey..
BTW They do seem to draw a lot of attention, so get ready..
Jetdr21 is offline
