Formula 382 >
Formula 382
Formula 382
Old 12-05-2002 | 08:58 PM
Wink Formula 382
I own a 2001 382 with 575 SCI's which runs at 83 mph, no Gen or A/C. After I bought it I had a Race Fairing built and installed,
powder coated the rails and a few other things. I came close to buying the 2000 Poker Run boat that was at Dick Simon just before buying this one. The one at dick simon has a A/C but no generator, and started with 540 ProChargers but has been rebuilt to some resemblence of the 540 Bulldog. This boat has had at least teo or three drive replacements that I have been told about. This boat is layed up a 1000 lbs light as I have been told. Good luck. I like my however I don't know how long 83 mph
will suffice.
bripar77 is offline
Old 12-06-2002 | 08:55 PM
John B's Avatar
I just bought a 382 with 525's. Is your speed gps or speedometer. Do you have extension boxes?
John B is offline
Old 12-16-2002 | 11:33 PM
PhantomChaos's Avatar
Default Re: Formula 382
will suffice.
I have a 382 with HP500EFI's (2001) with extension boxes.....I'm doing about 77-78 in the salt. I also have generator and AC. With the 575's, I would have thought that you would be faster than that. Is that GPS spped?
PhantomChaos is offline
Old 12-17-2002 | 05:44 AM
Audiofn's Avatar
Charter Member #232
I thought so as well Phantom. Sounds like some prop testing is in order Maybe a Herring????
Jon
Put your best foot forward!
Audiofn is offline
Old 12-18-2002 | 11:13 AM
Charter Member #415
The last 382 I sold with 575' and Stellings boxes ran 83-84 GPS,88-89 on speedo
Magicfloat is offline
Old 12-18-2002 | 10:40 PM
badasschevy
What do you think the speed would be with 500 efi with whipples ?. And how is this boat at upper 90s to low 100s?
Old 12-19-2002 | 03:04 PM
hot water's Avatar
My buddy has a 2001 382 with XR drives, extension boxes and Teague 800's. The boat has topped out at 100.5 gps. Up to 95 the boat is very stable after 95 the boat will sometimes chine walk violently if it encounters a boat wake from the side.
If you place Whipples on your boat (there goes your warranty)
you should get approx. 750 hp. This should put you in the mid 90's. Remember though after the expense of the Whipples you will need to upgrade those drives
hot water is offline
Lucky Strike Jr
07-19-2007 07:50 PM
kellyjo
Beware and Stolen
4
06-08-2007 07:58 PM
candyman
02-26-2007 07:57 PM
Toffen
07-28-2003 02:28 PM
