-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Relationship between the 242 and 272? (https://www.offshoreonly.com/forums/formula/41826-relationship-between-242-272-a.html)
RUSSSR1 01-29-2003 08:52 AM
Mopower
Do you have those 540's in your boat yet?:D :D
dockrocker 01-29-2003 02:44 PM
You guys are a bad influence - hell, a 330 hp in that little 24'er ought to be good for 60 or so, right? Fast enough... well, for now anyway :D
Come on W-2, I need to see if Mr. Taxman sees a new boat this year! :D :D
welly192 01-29-2003 03:23 PM
60+
I have this boat, 1 1988 242LS with 454 pretty much stock.
I get just over 60.
Ray
formula1 01-29-2003 07:28 PM
I had a F-242SS that I put a 468ci and Bravo I with a 21P prop, I couldn't get over 53 MPH out of it!!:eek: When a bass boat BLEW past me; thats when I sold it and bought a F-292 SR-1 with 454 mags:D ...now I see 70 MPH (and haven't seen a bass boat blow past me yet!)!! Luckily, the speed bug hasn't bit me, so 70 MPH is plenty.
Steve
mopower 01-29-2003 08:05 PM
Russ SR1,
Not yet , but getting closer day by day. Blocks are done , cranks balanced , rings file fitted , intakes and heads are gasket matched ,also some bowl work and a 5 angle valve job.
Heads still need assy and rods need to be sized , as I tried one of the pins and it was a little snug:eek:. Got new circulating pumps , new high volume Carter intern. reg. fuel pumps , new hp500 oil coolers. Still gotta order my crank driven sea water pumps. Got B & B polished and clear powder coated valve covers and the intakes and t-stat housings were powder coated magenta to go with the trim:cool: Blocks are black.
This is being done by a buddy's shop in between money making jobs that of course get more preferential treatment , after all he DOES have to eat and pay bills:rolleyes:
Got my dash ripped apart right now. New white panels are coming from Mear Image along with 17 new guages in white. adding oil temp , water press. and fuel press. to current arrangement.
The waiting is driving me:crazy:
RUSSSR1 01-29-2003 10:49 PM
Mopower,
You know you might just end up with one of the fastest 272's out there.:D :D If I remember right the hook was taken out of your hull befor you got it or was that someone else. anyway what are you gona do for drives? or is it gona be the right hand drive saver. I have been pondering the idea of updating the dash as well. Make sure to post plenty of pics when you are done.
Russ
mopower 01-30-2003 04:00 PM
Russ,
My bottom is factory with the two hooks right in front of the tabs:confused: . Not sure if this is good or bad.
My drives? Ones a 95 the other is an 02 standard Bravo. Time will tell:rolleyes:. There's people here who have run 6 or 700 hp thru them for years , and people who break the HP ones with HP500's.
It seems to have a lot to do with the way you drive:D.
My last boat had a 625hp , 710 ft lb torque 540 through an OMC King Cobra:eek: Guess what, it worked. Just listened to two OMC mechanics...no straight arm "hole shots" and don't catch too much "air" , that re-entry can play hell on drives. Three years later the current owner of my old one is still running the same drive , trouble free(with stock power).
I don't have a dig. camera yet , but my builder does , so as they go together I'll get some pix. Their also being dynoed:cool:
Also looking forward to hyd.steering for less than $500 too:drool:
jrocket 03-01-2003 12:46 AM
I have a 91 242LS with a real fresh 502 30 over all the wistlles in a naturally asperated motor Dyno a little on the high side of 450hp barely push 61 with my Hydromotive 4blade, spins 5300. With my Labbed Quicksilver 3blade I lick 65 but damn thats one heavy boat! Still love it though!
Rambunctious 03-05-2003 12:20 PM
dock..
Do it.
the 242 i sSO MUCH BOAT for a 24 footer!!!! silent thunder, and mc Cleod Interior, you can't beat it!!!!
or....... um...... buy my 272 with triple axle trailer for $15k more:eureka:
dockrocker 03-06-2003 12:49 PM
Hmmm.... unfortunately, I just finished the taxes over the past weekend. Mr. Gubberment has decided that I can go down to K-Mart and buy a plastic bathtub boat. Maybe. :(
