Show me yours Ill Show You Mine! (Formula That is) >
Old 12-28-2003 | 04:03 PM
  #151
Formula Outlaw's Avatar
Cal, do you have a stainless rubrail with the rubber insert or a one piece vinyl/hard rubber unit? I'm having a hard time picturing exactly what you've got there. I did the rubrail on my 242 and that was the aluminum/inset unit but it screwed to the boat from the outside under the black rubber insert. Then when the insert was installed, no screws were visible. I'll bet there will be some places where those machine screws will be a ***** to get at. Definitely gonna take 2 people. Keep me posted on how you make out. I personally like the one piece vinyl/hard rubber rubrail in one color. They are a snap to install. Good luck. Russ
Formula Outlaw is offline
Old 12-28-2003 | 05:12 PM
  #152
ljsmith1's Avatar
MOPOWER..
I just did mine on my 223LS this summer. The machine screws and aluminum backing plates are for attaching the deck/topside to the hull. These screws are countersunk into the fiberglass UNDER the rub rail. The rail is attached to the fiberglass with the sheetmetal stainless screws.
If you have a one piece, hard plastic rail, these are easy to get at through the face of the rubrail. If you have the 2 piece type (aluminum with a rubber insert), you need to pull out the rubber insert to expose the screws that hold the rail on.
To pull this insert out, you should find the seam cover at the stern of the boat and unscrew it. Then pry up one end of the insert. Pull the insert out all the way around, and start unscrewing the rail. If you try to do this now, you may want to bring a heat gun to soften up the insert to make it easier to pull out.
I went with a TACO 2 piece black rubrail on my boat. It came out great.
Good Luck!
-Larry
ljsmith1 is offline
Old 12-28-2003 | 09:28 PM
  #153
mopower's Avatar
Toxic FORMULA
Thanks lj,
Mine's the one piece style with visible screw heads. Looks like the hardest part will be bending the new one.
And perhapswhat appears to be large rivets holding the rail on the silent thunder swim platform
mopower is offline
Old 01-01-2004 | 06:04 PM
  #154
masi242's Avatar
I just this pic from our friends, it just reminds you summer is just around the corner, almost.
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-dscn0361.jpg
masi242 is offline
Old 01-01-2004 | 09:03 PM
  #155
bck's Avatar
bck
Charter Member#568
test
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-scan006-january-01-2004.jpg
Straight bottoms and flat decks
bck is offline
Old 01-01-2004 | 09:27 PM
  #156
cuda's Avatar
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-fpc-pic.jpg
cuda is offline
Old 01-02-2004 | 07:54 PM
  #157
Outlaw-
Were did you get the special fusion paint that you used for the rubrail?
Maritime_Eng is offline
Old 01-02-2004 | 07:58 PM
  #158
cuda's Avatar
419 At a poker run we were in.
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-dscf0027.jpg
cuda is offline
Old 01-22-2004 | 09:07 AM
  #159
bowtie89
ok its not as big as all of yours but it does the job
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-boat1.jpg
Old 01-22-2004 | 09:08 AM
  #160
bowtie89
Attached Thumbnails Show me yours Ill Show You Mine! (Formula That is)-backboat.jpg
