-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Kama Drives (https://www.offshoreonly.com/forums/formula/50956-kama-drives.html)
Jokers Wild 05-27-2003 09:28 AM
Kama Drives
HA GUYS I AM GOING TO REDUE MY KAMA'S!!! I AM GOING TO GO OVER TO THE PAINT SHOP AND TAKE OFF THE BOOT'S SO I CAN GET TO THE U JOINTS (KNUCKLES). AWHILE BACK I SAW SOME THREADS TALKING ABOUT HOW EASY IT WAS TO GET PARTS FOR KAMAS. SO I AM GOING TO GIVE IT A TRY!!!! IF YOU HAVE ANY INFO PLEASE LET ME KNOW. THANKS JOKERS WILD COME ON!!!!!!!!!
cuda 05-27-2003 03:30 PM
Team Archer Marine, 949 646 9778.
If you're going to replace the boots, it's easiest just to cut them off. They aren't cheap though.
Jokers Wild 05-27-2003 04:09 PM
i replaced the boots last year or the year before im not sure!!! BUT I KNOW THE KNUCKLES ARE IN DIER NEED!!!! THE BOOTS ARE EXPENSIVE- INFACT I HAD TO WAIT FOR THEM TO GET ENOUGH ORDERS TO RUN ANOTHER BATCH THE LAST TIME I ORDERED THEM HA THANKS CUDA I WILL CALL TEAM ARCHER!!!!!!! COME ON!!!!!!!!!!!!!!!
cuda 05-27-2003 04:25 PM
I've also "heard" that the gears can be bought other places that make gears. The ujoints may be some sort of standard use for heavy trucks too. Take it apart and take them to a place and find out. Let me know if you do. You know about parts, when you put "marine" in front of the word, just move the decimal point one place to the right on the price!:mad:
BTW, what did the boots cost you? I got a new set given to me when I bought the boat.
Jokers Wild 05-27-2003 04:29 PM
DAM CUDA I DON'T REMEMBER EXACTLEY BUT IT SEEMS LIKE THEY WERE IN THE HUNDREDS LIKE THREE!!! THAT IS PROABLEY PRETTY CLOSE AND THEY CAME OUT OF CALIFORNIA IF I REMEMBER RIGHT
Jokers Wild 05-27-2003 04:31 PM
BYE THE WAY CUDA I CALLED ARCHER MARINE AND THE GUY TOLD ME THAT SOME GUY NAMED DAN WAS THE ONLY ONE THAT NEW ABOUT KAMA STUFF AND HE WOULD BE BACK IN ABOUT AN HOUR. HE ALSO SAID HE THOUGHT THE U JOINTS WOULD BE NO PROBLEM
cuda 05-27-2003 04:37 PM
I think the guy I bought my boat from told me the boots were $600 a pair, so you are probably right on.
kaamacat 05-27-2003 06:09 PM
Phil....... Think the guy you might want at Team Archer is Gary. He used to work for KAAMA when they were around.
Also, for future reference. The rams are real easy, should you ever need to rebuild them. They just twist apart, and the seals are very standard. (cost is about $20 max for the seals).
Bob
cuda 05-27-2003 06:43 PM
Kaamacat, tell us about your boat. I'm always interested in any with Kamma drives.
jaf302 05-28-2003 04:53 AM
Hey boys, the gears are made by Casale engineering,the quick change v-drive boys. Paul
