-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   no sound from the rear speakers (https://www.offshoreonly.com/forums/formula/53809-no-sound-rear-speakers.html)
hauling ass-a 07-07-2003 09:58 AM
I have a 2000 271 and the rear speakers stopped working, does anyone know how to get the radio out? I figure a wire came off but don't know how to remove the radio.
ThirdBird 07-07-2003 11:22 AM
If yours is like mine, you need to pop the trim piece off the front of the radio and then slide a thin metal shim in on either side of the radio to disengage the locking tabs. The radio sits inside of a metal chassis, the chassis stays in place and the radio slides out.
Check your manual package you got with the boat, they should have supplied you with special metal shims for this purpose. If not, fab some up using sheet metal, thick feeler gauges or even a couple of butter knives might work. Just stick 'em in along the sides of the unit then pull the unit out. You'll see how they work once it comes out.
Good luck!!:cool:
hauling ass-a 07-07-2003 12:23 PM
thanks for the help, yesterday when I was looking Isaw two plastic knife looking pieces under the sink now i know what they are for now.
Audiofn 07-07-2003 08:44 PM
If you can not find the release tabs then let me know what kind of stereo you have and I should be able to tell you were the release tabs are and how to get them to pop
Jon
