242 impeller change >
242 impeller change
242 impeller change
Old 08-29-2003 | 02:50 PM
jrocket's Avatar
Default 242 impeller change
Belive my impeller is going down, water temp rising, oil pressure dropping at idle. I guess what I am looking for is how difficult is the change with motor in the boat and is there anything special I should look for? 502 single in 242 Formula? I was wondering anybody has any special suggestions. I hate learning from my mistakes
jrocket is offline
Old 08-29-2003 | 04:15 PM
If your oil pressure is going below 10psi at idle you have other problems than a watepump impeller.
The impeller is easy to change, when you do it order the one piece plastic kit, makes changing them alot easier.
RonS is offline
Old 08-29-2003 | 04:50 PM
hp500efi's Avatar
Member #9
Yes, by all means order the kit not just the impeller. Pretty easy change with proper (normal) tools and some patience.
Member of the Liquid Jungle
hp500efi is offline
Old 08-29-2003 | 09:51 PM
jrocket's Avatar
What would I be looking at? NEw power about 40 hrs on it. Motor runs flawlesly I figured due to the excaess heat that was the reason I dint stress but Im sure the motor builder will stand behind it
jrocket is offline
rssteiny
2
06-17-2008 02:59 PM
techman
15
04-18-2008 06:02 PM
jaxx 30
Scarab
5
04-10-2008 09:49 PM
RonA
7
05-31-2004 10:50 AM
jrocket
6
09-01-2003 06:37 AM
