Old 09-26-2011 | 08:01 PM
  #1541
Can you move the rubrail at all with your hands? This looks funny.....
formula 382 sr-1 is offline
Old 09-26-2011 | 08:39 PM
  #1542
J.B. Marshall's Avatar
JB Marshall
Uh Oh
J.B. Marshall is offline
Old 09-27-2011 | 07:45 AM
  #1543
lol, no but I do own a paint shop. That'll be a little winter project
CT232LS is offline
Old 09-27-2011 | 08:39 AM
  #1544
PhantomChaos's Avatar
What do you think caused it to look like that?
PhantomChaos is offline
Old 09-27-2011 | 08:44 AM
  #1545
I would assume bumping against a dock and Formula not painting under the rubrail causing an adhesion problem in that area. I'll eventually have the colors photo matched by ppg and fix her up a tad but for now Ii'm gonna focus on making sure the boat's reliable. Went out last weekend for the maiden voyage and all was good so far. One weak battery that i'm gonna change this week but other than that i'm pretty happy with the boat
CT232LS is offline
Old 09-27-2011 | 01:03 PM
  #1546
Thats common when Formula painted thru the rub rail like that doesn't take much to chip the paint like he said mayb e a bump on rail, not even enough to mark the rubrail up either, just a weak spot in the paint on the joint
88242LS is offline
Old 09-27-2011 | 01:52 PM
  #1547
PhantomChaos is implying that your deck to hull joint may be coming loose and that the problem may be more than cosmetic. It’s worth a look, but it could also be caused by what 88242LS said. Formula paints the rub rail along with the deck and hull so some chipping is inevitable.
JTeam is offline
Old 09-27-2011 | 02:13 PM
  #1548
Ya, the rub rails nice and tight along with the deck to hull joint. After 16 years out in the sun a simple pressure wash could probably be enough to blow that area loose if it wasn't caused by bumping into the dock. Most likely the way they painted the stripes right over the rub rail the paint was probably connected to the deck with paint until this happened. All it would take is a little flex from bumping the dock or some high pressure water getting underneathe the area
CT232LS is offline
Old 09-27-2011 | 03:15 PM
  #1549
Thumbs up
Old 09-30-2011 | 09:45 AM
  #1550
Registered User
More more more !!!!!!!!!!!!!!!!!!!!
Muscar311 is offline
