Project 311 SR1
#71
On another note I am in the process of redoing the sundeck of the boat so it is all white. I am going to make it out of one piece instead on the individual sections. I am hoping that this will give the boat more of an updated look. I was wondering if it is possible to exactly match the white vinyl used in the boat? I have talked to a few shops around here that can come close but it is not a perfect match. Any help would be great.
#74
Originally posted by Chart
An upholstry guy once told me NOT to just use one piecs of fabric on the sun deck or it will bellow in the wind.
#77
IF you glued the fabric to the foam, it might not bellow. But you would need to also glue the foam to the hatch. Personally, I'd worry that one piece of white would look generic, not classy like other Formula white interiers.
#78
The back sun deck is not going to be one piece white. It is going to be like the new formulas are with the one piece of vinyl that is multi colored with a design. I just want to get way from the multi section sundeck.
#80
Hi Wes-
Thanks for the Info! I would have found that out this weekend when I was working on the boat. Did you just replace the wood or did you replace the foam too? Just curious?
Don
Don
