Att 382 owners-CMI mufflers and P-5's >
Old 04-25-2004 | 02:38 AM
  #31
RedDog382's Avatar
Lonestar382,
Still would like to see what you run with the original 28 Bravo's. I think you will find something around 5000 r.p.m. and 74-75 m.p.h.
RedDog382 is offline
Old 04-25-2004 | 08:15 PM
  #32
John B's Avatar
Corey, The Stellings can be installed at three different heights, one inch apart. Where did they locate your boxes? You should check this with them.
JB
John B is offline
Old 04-26-2004 | 09:30 PM
  #33
I will definitely do that. Does that mean that I should be able to raise them if they were installed lower???
I would definitely try for that. How hard a task would this be?
Thanks again for all your help, I will talk with them tomorrow and find out how they were installed.
Corey
lonestar382 is offline
Old 05-06-2004 | 10:49 AM
  #34
Hey Lonestar, Boxes won't give to much more speed than without, but it helps the boat get on plane faster with any more throttle. Props get a cleaner bite further back and hold the nose up higher at wot. Try running prop turning in. Just swap them and put in reverse to go foward for a test. If you have 500efis in your 382 you should be at around 72 to 76 on gps maybe more depending on conditions. Labs 30 would be a good start. On your stelling boxes they should be bolted up in the middle hole to the transom. To see this u will have to remove a inspection port on the box and look inside. Hope this helps. Steve
OffDuty is offline
Old 05-07-2004 | 02:38 PM
  #35
thanks Steve,
The boxes are set on the middle hole currently, and I am thinking of raising them up one notch. labbed 30's
I am running labbed 24's and am hitting 72@5400. I plan on installing a set of 26's as soon as I can get ahold of them.
I am probably going to try and raise the settings on the boxes after this season and see if that gives me any help on top end.
thanks for your help, and I will let you know what I come up with.
Corey
Nykamp
Swap Shop
0
10-28-2008 07:26 PM
kidapache
Swap Shop
2
08-06-2008 03:07 PM
JBYRD65
Active Thunder
2
10-21-2007 09:41 AM
Ateco
Pantera
1
05-16-2006 07:27 PM
Clay Avedisian
Hustler
0
12-03-2002 02:49 PM
