What's Inside Silent-Thunder Exhaust? >
Old 04-13-2004 | 06:50 AM
Formula Outlaw's Avatar
I also have it on good sources that Troutly used to keep "Pictures" hidden inside his silent thunder for "emergencies".
Formula Outlaw is offline
Old 04-13-2004 | 12:49 PM
RUSSSR1's Avatar
For people that want to see the inside of the SR1 silent thunder I will attach a couple of photos. I removed mine because the hull platform gasket was leaking as well I had some cracks at the tow hooks. What I found was the backside was completely rotten. I cut all this out and glassed in a new piece. the job was relatively easy and now I have no leaks or rattles.
RUSSSR1 is offline
Old 04-13-2004 | 12:51 PM
RUSSSR1's Avatar
Tow hook cracks, if you have them I would look for rott in your platform.
RUSSSR1 is offline
Old 04-13-2004 | 12:54 PM
RUSSSR1's Avatar
Area of rott that I cut out
RUSSSR1 is offline
Old 04-13-2004 | 12:56 PM
RUSSSR1's Avatar
Good inside shot of the parition that many people take out
RUSSSR1 is offline
Old 04-13-2004 | 09:10 PM
WAGS382's Avatar
ApachePete,
I haven't run the boat yet with the new silencers, I'm shooting for the 1st of May. Jeff
WAGS382 is offline
Old 04-13-2004 | 09:24 PM
ApachePete's Avatar
I'd like to know how the silencers compare to Silent Thunder in the "quiet-mode."
ApachePete is offline
Old 04-14-2004 | 11:30 AM
Default Re: What's Inside Silent-Thunder Exhaust?
Originally posted by ApachePete
Specifically, is the exhaust from both pipes in an engine dumped into a common chamber?
I ask because the transom on the port side, around both exhaust outlets, is suddenly black with soot. The motor run and sounds just fine. HP500EFI's
I was wondering if it could be stuck injector, dumping too much fuel in one cylinder. But for that to be the problem, the exhaust from both cylinder bank would have to intermix.
Any ideas?
Thanks!
We need to get this thread back on topic. The original question involved sooting at the "transom".
Is the soot showing up at the actual transom or at the actual exhaust outlets in the silent thunder platform?
If its at the transom (where the exhaust chamber mates-up), then you have a leaking chamber seal at the transom exhaust tip and at the peripheral seal. This is allowing exhaust gas to seep out without going out through the exhaust chamber. Some sooting is normal and if you have a leaking platform system, it will show up as sooting.
However, if you only see the sooting at the actual exhaust outlets at the back of the exhaust platform on one side and see no sooting at the other side (other engine), then there is obviously an engine problem. Could be anything from fuel delivery to spark to valves, whatever.
Got any pics?
ThirdBird is offline
Old 04-14-2004 | 11:45 AM
ApachePete's Avatar
Problem is heavy soot at the exhaust tips on the port side, which is so bad it covers one half of the underside of the Silent Thunder, as well as most of the transom below it. Problem began suddenly after I picked up sand and that engine's water temp went to 200. Still runs fine, power-wise.
Seems that the water temp sensor could have been clogged or damaged, telling the motor it hasn't warmed up yet, so it goes into an over-rich mode.
Haven't found anyone with a scan tool, so I'll switch the sensors between motors and see if the problem goes to the other one.
Any other ideas? Are these sensors prone to problems? I've picked up sand and overheated MANY times, but never had this problem before, so I'm not sure it's any more than a coincidence.
Formula Outlaw
05-09-2012 11:59 AM
hot water
07-11-2007 07:28 PM
formula1
05-01-2006 04:10 PM
zelinsm
1
04-23-2004 07:43 PM
OldSchool
09-03-2002 09:12 AM
