docking light bulbs? >
Old 05-03-2004 | 08:06 PM
Liquid Fix's Avatar
hey thirdbird,
i got them at the local auto parts. i took my old one with me and they matched it. i would try a good "old school"
parts house. you know how bad the auto zones and such can be. "well, we can't find -thunderbird formula- on the computer so i don't think we carry that".....
Liquid Fix is offline
Old 05-03-2004 | 08:51 PM
Originally posted by Liquid Fix
hey thirdbird,
Exactly!!!! Those parts stores are staffed by rivit-faced, tattoo'd, floppy pants, dumphuk punks that wouldn't know a Formula Thunderbird from a Ford Thunderbird.
If all you need is Armor All or spark plugs or cheapo replacement hub caps, Auto Zone is fine. But, I agree, you need a good supply shop with lots of stock run by an adult who's driven a car for more than two years and has actually worked on one or two in his/her day.
There,,,,,,, now that I got that off my chest,,,,,,,, thanks again for the info Liquid
ThirdBird is offline
Old 05-03-2004 | 10:24 PM
dawiz74's Avatar
Thanks, for all the info, I'm on the road and just got internet service tonight. I guess i'll replace both bulbs, so they look the same.
Hey Liquid Fix, do you like the spots better?
dawiz74 is offline
Old 05-03-2004 | 10:45 PM
Liquid Fix's Avatar
dawiz74,
i have not had a chance to run the boat at night since i installed the spots. i really looking forward to see if they light the tralier up better when loading at night. i might run the boat in the next day or two and i'll check back in and let ya'll know.....
Old 05-17-2004 | 05:47 PM
dawiz74's Avatar
Default Re: docking light bulbs?
I called Formula and they said you could replace the bulb by prying the rubber boot apart. They said you might have to use a razor blade or sharp edge to get it apart. The guy told me the replacement bulb was a GE 4519. I found them through Grainger @ http://www.grainger.com/Grainger/pro...594456&ccitem= . I called O'Reilly's and they said it was a bad number, but they have a 4419 that is only about $13, but the candle power is only 1600? The 4519 is $35.00 and your only getting an average of 25 hours of usage, but at 30,000 cp's. All this is irrelevant until I get the rubber boot apart, which I have tried a couple of times already! I can't figure what part seperates? There is an approx. 1" ring that goes around the boot. Is this where it seperates?
dawiz74 is offline
Old 06-11-2004 | 11:19 AM
CMG's Avatar
CMG
ttt
Chris G.
CMG is offline
Old 06-25-2011 | 01:07 PM
anyone have a bulb replacement number for a 2003 fastech 292?
port side dock light went out.
1MOSES1 is offline
Old 06-25-2011 | 04:23 PM
WOW!
Rippem is offline
Old 06-26-2011 | 09:53 AM
i pulled mine. its a two prong 12v 35w bulb with a uv filter lens on the front. hope this helps anyone who needs one.
1MOSES1 is offline
Old 06-26-2011 | 09:50 PM
Default Dock lights
I got mine at Home Depot,,,,,......really exact match
fossil fuel is offline
