Silent Thunder "box" removal question >
Old 06-06-2004 | 10:01 AM
Formula Outlaw's Avatar
Default Silent Thunder "box" removal question
Okay, it's been awhile since I've asked a stupid question. How many bolts does the silent thunder box have in attaching it to the transom? I think I know but want to be sure. Thanks. Russ
Formula Outlaw is offline
Old 06-06-2004 | 10:03 AM
CMG's Avatar
CMG
Default Re: Silent Thunder "box" removal question
2 on each corner
CMG is offline
Old 06-06-2004 | 06:11 PM
causin trouble's Avatar
My 353 fastech had two on the corners of the swim platform and two on the transom with stainless L brackets ...
causin trouble is offline
Old 06-06-2004 | 07:29 PM
Thanks guys. It looks as though someone added two extra bolts on each side at the bottom with a steel backing plate. No matter how many there ,THAT SUCKA IS COMING OFF.
Old 06-06-2004 | 08:45 PM
offthefront's Avatar
Russ ....take some pics of the process ....
offthefront is offline
Old 06-06-2004 | 09:04 PM
Thumbs up Re: Silent Thunder "box" removal question
Now we both know if I do that (which of course I will) you'll want to take yours off too. Maybe you should trailer down and we could have one big "off goes the muffler" party. I'm really psyched. I saw a 311 last year without the box and boy did it ever look good, just completely cleaned up the back, and I still hate those rectrangular exhaust tips. They just don't look right.
I can't make my mind up if I want internal flappers or not on the new tips. I keep hearing they burn out but then I don't like the looks of the traditional "Salsbury Flapper" either. And I think it's a good idea to have some kind of flapper. Any ideas anyone?
Old 06-07-2004 | 11:31 AM
Two u-bolts at top, two brackets at bottom, outside corners, two small "L" brackets at bottom middle.
That was a pretty goofy question Outlaw, since all are visible from the back of the boat!!!
ThirdBird is offline
Old 06-07-2004 | 12:04 PM
Talking Re: Silent Thunder "box" removal question
I told you it was a "stupid question". I'm good at those. I just wanted to be sure there wasn't something that was not easily visible that could cause a problem with everything else off, you know like one bolt somewhere while the box is hanging precariously above the outdrives, which I just finished sandblasting, sanding, priming, and repainting. Thanks.
Old 06-07-2004 | 01:35 PM
:d :d :d
Old 06-07-2004 | 01:36 PM
:d :d :d
Supposed to be "Big Grins", didn't work though.
