Removing old "thru-hulls"... >
Old 10-10-2004 | 04:01 PM
Formula Outlaw's Avatar
Default Removing old "thru-hulls"...
Okay, I'm trying to remove the old very short thru hulls on my 89 311 SR1. They are acting like they are "glassed in". I've tried twisting them with BIG water pump pliers to break the seal, no luck.
I'm thinking of trying to heat it with a heat gun but I really don't think that's gonna do much, I mean they are used to heat. I don't think getting a big block of wood and trying to beat them out from the inside is the best idea either.
I could use some suggestions....Thanks. Russ
Formula Outlaw is offline
Old 10-10-2004 | 11:29 PM
RedDog382's Avatar
Default Re: Removing old "thru-hulls"...
Russ,
I think these may have ben glued in with 5200. If so, they will be a bear to get off. I have heard of guys cutting the 5200 behind trim tabs with a piano wire, so you might want to try that if you can get a little edge to get behind. Otherwise, you will probably end up ripping off a chunk of gelcoat with it if you go the BFH route (had a "expert" marine mechanic do this to a trim tab on my 311 - $560 to repair ).
RedDog382 is offline
Old 10-11-2004 | 06:37 AM
Audiofn's Avatar
Charter Member #232
The Piano wire trick works (or guitar string ot other like things) Heat does help. Remember your exhaust is actually fairly cool by the time it gets to that point. Just b carefull not to heat it up to much or you can discolor the gel.... Good luck.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-11-2004 | 02:58 PM
"5200", the one number I did not want to hear......Thanks for the suggestion. I guess you go to a piano store to get piano wire huh???? Don't think I've ever had a reason to buy piano wire. Russ
Old 10-11-2004 | 03:01 PM
ElDiablo206
Maybe try fishing line??? Don't know if it would work though(its cheap)
Old 10-11-2004 | 06:43 PM
I don't think that fishing line has the "cutting" qualities that thin piano wire has. But thanks for the thought.
I put this question on the general boating discussion forum also, and somebody came up with a good idea involving shoving an eight ft. 2x4 with a cloth wrapped around it for tightness then jerking it from side to side to try to break it loose. I think I'll try that first.
Thanks for the help. R
Old 10-12-2004 | 12:25 AM
RedDog382's Avatar
... unless you're a highly paid mercenary on a very covert special op.
If I remember correctly from the movies, they used a small wooden dowel at each end for handles to pull on.
Old 10-12-2004 | 07:50 AM
A "silencer" makes your work easier and more "long distance".
Yes, I believe, from my movie memory, that dowels are the way to go and I just happen to have a whole bunch, I think a 3/4 inch would be the way to go. One way or the other I'm gonna get these things off. Now it's "personal".
Thanks for all the suggestions.
Except my wife's, hers was to sell the damn boat.
Old 10-12-2004 | 09:36 AM
Audiofn's Avatar
Charter Member #232
Ok so sell it as long as she said you can get something bigger and newer
Audiofn is offline
Old 10-12-2004 | 06:27 PM
For sale: one wife, bossy, stubborn, my way or the highway attitude, did I say stubborn. Free or best offer.....
