silent thunder platform ?'s
First of my formula is a 1989 206 w/thru hull exhaust the platform is starting to look faded and its starting to leak around the gasket. so...this winter I am planning on pulling it off and doing 1 of 2 things..
1) fixing the gasket and cleaning it all up then putting it back on 2) taking it off, cleaning up the transom , putting some nice tips on it and putting on one of those extreme marine powdercoated platforms. Has anyone done this? Do you have any pictures? Will I have any problems? and the last thing is how much does the silent thunder platform weight? also one from extreme marine? thanks alot for your help, Harry |
Re: silent thunder platform ?'s
If it makes any difference to you , after you remove your Silent Thunder your boat will look 2 feet smaller :( .Right now , with the platform , it looks like most 22'6" boats :cool:
I thought about that also...its one of the things that will probably persue my decision once I have the platform off.
There are several threads on OSO about the very subject you're asking.
Do a search. Platform weighs about 200 lbs. I believe there are six bolts holding it to the transom. Some people have had trouble breaking it lose once the bolts/nuts are off. Some recommend having three very strong friends or a fork lift to catch it when the bolts are undone. Contact OSO member Magicfloat, he is a Formula dealer and can order the new transom gasket and seals. Last I heard the price was around 25.00. |
| All times are GMT -5. The time now is 11:23 AM. |
