Slight snag in exhaust swap out >
Old 10-28-2004 | 04:10 PM
ljsmith1's Avatar
Default Re: Slight snag in exhaust swap out
I was just about to say that with the metal flex pipe, the main problem would be clamping it on and getting a tight seal. My advice is to either make a proper spacer (if that will solve the alignment issue), or trade in the tube risers for something a bit shorter and angled correctly. I don't think you would lose significant HP with a riser change.
I also concur with dgduck13 and know that you will not get a water tight seal. Not to mention, I don't think the USCG would approve of a hose that has the possibility of leaking H2O and exhaust fumes into your engine compartment.
Other than that, you might need to glass up your through hulls and make another set of holes...not exactly a fun project.
Good luck and keep us posted!
-Larry
ljsmith1 is offline
Old 10-28-2004 | 05:14 PM
Formula Outlaw's Avatar
I'm just going to install 3 inch spacers, run the hose off the risers, add a slight curved pipe to make the angle correct back to the holes in the transom, run a hose to the new tips, and be done with it.
Formula Outlaw is offline
Old 10-28-2004 | 07:55 PM
offthefront's Avatar
Originally Posted by Formula Outlaw
Mike, are those black things your original tips? Mine were "normal" looking, just extremely short, only extended an inch past the transom. Russ
the one one the right is the stock tip ..if you look close you can see the old flapper assembly inside ....
offthefront is offline
Old 10-28-2004 | 09:36 PM
My flappers were much worse, and two were gone all together.
That box turned into a real bi*ch to remove. Someone had it off at one point and installed extra mounting bolts that we couldn't see. Had to call Mr. Saz-All to help with removal, he took care of that little problem with ease.
Old 10-29-2004 | 08:33 AM
Worse ??? Mine were GONE ...
Old 10-29-2004 | 05:19 PM
Eyesight is going to hell, guess it's cables I was looking at. I had two completely gone and two were "remnents" of what was......
And what was is what was, ain't no mo'........
Old 10-29-2004 | 05:52 PM
cuda's Avatar
Getter done Russ! Did you go to the meeting last night?
cuda is offline
Old 10-29-2004 | 06:15 PM
No, intended to, but at my follow up exam yesterday, xrays showed stitches holding fine but bloodwork showed an infection starting. "Doc" sent me home with these monster antibiotics with orders to do nothing and go nowhere for at least 72 hours so the antibiotics kill the infection.
So I'm lazin' it.
Daytime TV sucks.....
Done a lot of reading....
Old 10-30-2004 | 07:47 AM
Boat goes up to the shop on either Monday or Tuesday morning to get the motor pulled to get the manifold off. Then it's "put it back together" time. Getting closer.
bigbsbigblocks
12-14-2006 08:35 AM
formula1
07-15-2006 12:27 PM
JasonSmith
Baja
4
11-25-2005 01:32 PM
rkeith01
17
02-20-2005 12:12 PM
Formula Outlaw
08-12-2004 08:59 PM
