Replacement hatch hinges for a 84 302. >
Old 11-05-2004 | 07:34 PM
Default Replacement hatch hinges for a 84 302.
Any one know where to get replacement hinges for the rear hatch? I'd like to stay with the original style/mounting holes.
Thanks,
Bryan
Bryanw is offline
Old 11-05-2004 | 07:39 PM
cuda's Avatar
Default Re: Replacement hatch hinges for a 84 302.
Have you had any trouble with the bolts pulling through?
cuda is offline
Old 11-05-2004 | 07:54 PM
It looks like the prior owner added an aluminum plate on the back side of the plywood. That kept the bolts from pulling through. My issue was the bolts would turn when you tried to tighten the hatch.
Bryan
Bryanw is offline
Old 11-05-2004 | 09:24 PM
cuda's Avatar
My previous owner did the same thing, but the stainless is along the outside, looks good really.
Formula Outlaw and I were discussing on the phone how much these damn hatches weigh. They are heavy!
cuda is offline
Old 11-06-2004 | 12:00 PM
They are really heavy. I have mine apart right now and I was suprised how heavy the fiberglass is.
Bryanw is offline
Old 11-06-2004 | 04:39 PM
cuda's Avatar
The hinges should still be available through the dealer.
cuda is offline
Old 11-07-2004 | 10:59 AM
RedDog382's Avatar
I don't think it's the fiberglass that weighs so much. I had the hatch from my 311 dis-assembled a few years ago. All the foam and plywood sections were saturated with water and this significantly increased the weight of the hatch. I dried out the plywood panels and replaced all the foam with the foam now used in the new Formulas that repels water. The assembled hatch was so much lighter that I was able to lift it up onto the boat and reinstall it by myself.
RedDog382 is offline
LubeJobs42
10-10-2006 02:22 PM
toolz
Fountain
2
05-17-2005 02:15 AM
88formula223
05-12-2005 01:42 PM
hauling ass-a
07-24-2003 08:17 PM
Bajaforce
Baja
4
02-06-2003 12:33 PM
