-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Not enough gauges! (https://www.offshoreonly.com/forums/formula/98125-not-enough-gauges.html)
CObarry 03-11-2005 05:06 PM
Not enough gauges!
1 Attachment(s)
My 336 is woefully short on gauges, and I don't really care for the look/design of the current panel. Reading the other thread on panels is giving me ideas of starting over with a blank sheet of paper. Some of the gauges I'd add would be:
  • A second voltmeter (how can there only be 1?!?)
  • Oil temperature
  • Drive oil temperature
  • Ammeters
  • Built in GPS chart (would probably have to be small)
Are there any other cool gauges/monitors worth adding?
Current panel:
PhantomChaos 03-11-2005 05:22 PM
Re: Not enough gauges!
Maybe water pressure?
The dash I'm doing is on my 382. This is my second project. I re-did my 1997 Fastech 312 about 4 years ago. I got all the parts from a Formula Dealer so it was pretty easy. Nothing custom.
Old
http://www.vxi.cc/312/images/P0002053.JPG
New
http://www.vxi.cc/312/images/P0002132.jpg
CObarry 03-11-2005 05:30 PM
Nice upgrade!
I hadn't thought about water pressure, but that's a great idea...instant notification if you lose an impeller or a water pump... :cool:
292SR1 03-11-2005 05:38 PM
NICE upgrade!...........was never a fan of the grey dash.
I put a Nordskog GPS speedo in my 292 and LOVE it. Even reads speed backwards!
Would recommend this definitely as an upgrade or similar from another mfgr.
PhantomChaos 03-11-2005 06:05 PM
Thanks..........pretty silly, but I threw all the old parts away. Then I posted my pics when I finished it and some guys wanted to by the VDO stuff from me. Oh well.
You can see how they spaced the gauges so it is easy to add a GPS right in the middle (where the "FasTECH" is). I couldn't get that "FasTECH" thing to stick to the dash on the other side since that thing got so hot during the summer.
offthefront 03-11-2005 06:34 PM
I can see all cept ammeter ....maybe ... it would indicate alt output ? if you watch voltmeters ... if alt quits the voltage will drop .... I do question one voltmeter ...unless there was a switch to check each output ....
  • Oil temperature
  • Ammeters
Current panel:
mopower 03-11-2005 06:34 PM
2 Attachment(s)
[*]A second voltmeter (how can there only be 1?!?)
Current panel:
How come there's only one??? Because that's the way it's wired.
Meter reads the output of the battery switch and that means what ever battery is selected. My 1989 has two voltmeters and the both read the same. If I run one battery they both read that one. They are not set up to read the battery associated with the engine on that side.
I added fuel pressure , oil temp and water pressure :cool:
ThirdBird 03-11-2005 06:43 PM
Meter reads the output of the battery switch and that means what eer battery is selected. My 1989 has two voltmeters and the both read the same. If I run one battery they both read that one. They are not set up to read the battery associated with the engine one that side.:
Mopower,
I didn't know that. That's good info. :cool:
mopower 03-11-2005 06:50 PM
Third,
Next season , turn on one battery and one ignition switch. Next start the other engine and watch the one that's not running. You'll see what I mean. That's why Formula dropped one guage ;)
obnoxus 03-11-2005 07:56 PM
I THINK YOU SHOULD SELL IT !!!!!!!!!!!! :D :D :D :evilb: :evilb: :evilb:
hillbilly24 03-11-2005 09:50 PM
Old
New
Where's your maveric Marine key floats? no love for Eric huh
PhantomChaos 03-11-2005 10:37 PM
That was before he gave me some! :D :D Got them now!
hillbilly24 03-12-2005 12:20 AM
as long as your properly equipped now :D Tell Eric I said hay when you see him.
offthefront 03-17-2005 10:54 AM
Cal .. first Time I've seen the dash ...looks nice .... you guys begining to thaw ???
mopower 03-17-2005 12:11 PM
Yeah...normal highs now about 54/55. Couple more weeks till the "unwrapping party". Usually around the beginning of April.
Still waiting on my new heads also.
Goofy1103 03-21-2005 09:05 AM
1 Attachment(s)
Add Smartcraft Monitors
offthefront 03-22-2005 05:34 PM
Third,
Tried the voltmeter test today .....mine are separate ... if you start one motor only that Voltmeter indicates Voltage ....
cuda 03-22-2005 07:04 PM
1 Attachment(s)
Mine has two voltmeters also.
offthefront 03-22-2005 07:07 PM
Mopower was saying that both Voltmeters are tied together ....in mine its not the case ....
mopower 03-22-2005 09:01 PM
No no , they're not tied together , rather there is only one 12v source coming from the batteries in the back. If bat 1 is selected both read 1. If bat 2 is selected both read 2 . If both are selected they read both.
You can tell by turning one ignition on and reading the volt meter(engine not running) now start the other engine and watch both volt meters...they will both charge :eek: .
Now shut iff the one that's running and both meters will drop ;)
PhantomChaos 03-22-2005 09:09 PM
Sounds like you have your battery switch set to "both", or you're wired up wrong.
offthefront 03-22-2005 11:00 PM
Hmmm.... get back with ya ..... :rolleyes:
