-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   292 T/6.2 Has anyone tried other props?? (https://www.offshoreonly.com/forums/formula/99545-292-t-6-2-has-anyone-tried-other-props.html)
docbones 03-30-2005 09:42 PM
Has anyone tried any other props on 292 with 6.2`s? If so what performs best? Also what other improvements have you done that helped performance?
Thanks,
Docbones
Bikini Bottom 03-31-2005 11:55 AM
Re: 292 T/6.2 Has anyone tried other props??
I have the Labbed Merc Bravos now, I'm not getting more than about 4900-5000rpm most days. Throttle-up recommended dropping down two inches in pitch since Formula tends to over-prop it's boats. I'm holding off until I have the exhaust modifications finished. I yanked the silent thunder box over the winter and plan to install new performance manifolds...so I don't want to buy props twice. If I don't use Mercs, my other idea is to try a set of Hydromotive P5X's...I hear they're good on the Fastechs. Good luck and let me know what ends up working best.
bottomfeeder05 03-31-2005 06:45 PM
Ill be trying 24s and 26s tomorrow {Bravos non-labbed} Ive got the same boat, engines but different gear ratios, see my thread props and gear ratios
bottomfeeder05 04-01-2005 06:07 PM
Ran 24s today, didnt bother with the 26s ,64 mph 5000rpm,1.50 gear ratio. Got on plane better then the 28 labs but lost speed. What's everybody else getting for speed in this boat with 6.2s??? Anybody try some Whipples?
Bikini Bottom 04-04-2005 11:37 AM
I've got Scorpions but I know the 6.2's should run a consistent 70-72 stock. Haven't seen any with Whipples but sure would be interested in what it'd do!
bottomfeeder05 04-04-2005 05:02 PM
I had a DCB Mach 22 a couple years ago that had a scorpion motor with a whipple on it, 87 mph 22 ft cat, not bad!!!
Bikini Bottom 04-06-2005 04:13 PM
That's a good number on a 22' boat! What other modifications did you have with the Whipple? I'm interested but I have to wait until next year. Besides the top end how was the performance and reliability?
bottomfeeder05 04-06-2005 05:41 PM
I bought the boat used, from DCB no mods to the motor good idle 6-7 lbs of boost. These DCB 22ft cats are fast!!! They were designed for outboards but theyve built some sterndrive boats.Twin 300 Merc drag motors on this rig runs over 130, not for the faint of heart!!!!!
Bikini Bottom 04-07-2005 06:43 AM
Holy smokes...a buck-thirty sitting what a couple feet off the water. That must be like driving a 100mph go-cart! I'd never get Mama out there other than the first ride.
When are you going to whipple the 292? It'll be a nice set-up I bet.
bottomfeeder05 04-07-2005 09:57 AM
Im about 90% sure Im getting a 04 353 with boxes and 575's so the 292 will be for sale {maybe}
