-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   27 Cabin door lift strut (https://www.offshoreonly.com/forums/fountain/100884-27-cabin-door-lift-strut.html)
35 White Lightning 04-17-2005 05:55 PM
Anyone know where I can get a new attwood lift strut for a 93 27 Fever. Mine won't hold up anymore
fourplaydave69 04-17-2005 07:07 PM
Re: 27 Cabin door lift strut
I got one from West Latrine, but check marine.com it might be a tad cheaper.
blownincome 04-17-2005 07:39 PM
I can set you up let me know think thy are about 22.00 plus shipping
US1 Fountain 04-17-2005 07:56 PM
I've replace mine on both my 27 and 32. Bought both from WM.
Don't understand why, but if you look on the original strut, they will have a sticker denoting the # rating. Peel that sticker off and it has a different rating painted on from the strut maker. I 'think' the sticker is lower rating???? Anyways, I always bought the heaviest one available.
BZ 04-18-2005 12:41 PM
get the one with the biggest rating you can they last longer....
Ran-Dom 32 04-21-2005 03:35 PM
Are they an in stock item @ West Marine?? mine seems to be getting weak also on my 35. same part I believe.
35 White Lightning 04-22-2005 08:33 AM
Is the one you have the same as the original or is it a higher rating? Are you set on pay pal. Thanks Brian Leith
AMERICAN BAD A$$ 04-24-2005 04:07 PM
I just replaced mine through Fountain , not expensive at all and it's stainless .
jmeng 04-24-2005 09:24 PM
On my dad's 35 we replaced the strut with a higher weight one. Worked great, actually had to use two hands to push it down.
