water pressure guage >
Old 04-29-2005 | 07:53 AM
35 White Lightning's Avatar
Registered User
Where does the factory pick up the water pressure for the wp guage. My hose is curled up and zip tied and not hooked up
35 White Lightning is offline
Old 04-29-2005 | 08:50 AM
Ran-Dom 32's Avatar
Default Re: water pressure guage
there is a brass fitting in the block SB side. They can become clogged with sand & debries very easy & become inoperative.
Ran-Dom 32 is offline
Old 04-29-2005 | 09:29 AM
pachangalpina's Avatar
Mine are on the port side and tee'd into the block drain. Sounds like which ever side they are on it is incorporated into the block drain. I am contemplating moving mine.
pachangalpina is offline
Old 04-29-2005 | 10:33 AM
tssteph's Avatar
Mine to.
tssteph is offline
Old 04-29-2005 | 06:45 PM
blownincome's Avatar
Originally Posted by tssteph
Mine to.
Mine 3 I think im going to plumb it off the T stat houseing
blownincome is offline
Old 09-04-2005 | 11:57 AM
Where would you put the sending unit on a closed cooling system?
Badtoon is offline
Old 09-06-2005 | 01:50 PM
Registered User
I drilled and tapped a barbed 90 degree tee on the out side of the seawater pump. Seems to work ok
dicdik
Do It Yourself, Boating on a Budget
4
07-09-2008 02:28 PM
RedDog382
08-06-2007 09:16 PM
ls1nova
8
06-13-2007 09:27 AM
Donzi35ZR
5
09-18-2006 04:16 PM
scottsumrall
16
08-20-2002 11:26 PM
