shorties on a single step >
Old 08-16-2005 | 08:37 PM
carney's Avatar
Default Re: shorties on a single step
Candyman, You must be saying that fountain raised the motor first ,then used the top hole in the stellings box. Yes mine are stellings. But if I put mine in the top hole that will put the drive lower in the water. It will lower the ext box. The bolts are in the bottom hole now and I can not trim the drive with out them hitting the swimplatform. and with the drives against the platform at 5200 there is no rooster at all. I think this is slowing the boat .??????????????
carney is offline
Old 08-23-2005 | 08:30 PM
carney's Avatar
I checked the drive height tonight, they are 4inches from the bottom of the boat to the center of the prop shaft. Does anyone know what this should be with boxes?
carney is offline
Old 10-05-2005 | 07:49 PM
Ran-Dom 32's Avatar
I will be posting before & after results on my 35 going from stock bravo drive to -2 sportmaster lowers - going to run same props (28b1s) & borrow a set of 30's - hopefully pick up some MPH
Ran-Dom 32 is offline
Old 10-06-2005 | 07:51 AM
carney's Avatar
That would be great. What power do you have.
carney is offline
Old 10-06-2005 | 08:07 AM
Ran-Dom 32's Avatar
500hp's w/upgrades
Old 10-07-2005 | 01:43 PM
carney's Avatar
If we get the rain that is due , you will not be able to test. I hope they work out for you.
carney is offline
Old 10-07-2005 | 05:37 PM
Ran-Dom 32's Avatar
they are bolted on & ready to go - just waiting for the weather to co-operate
Old 10-07-2005 | 08:03 PM
10x's Avatar
10x
10x
On a SSM IV or V, my prop shafts are 1" below the bottom of the hull. That's with Merc 12" boxes.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 10-08-2005 | 08:54 AM
hi guys iv'e had my 2" shortys on my 97 single step for 3 years,i picked up 5 mph just bolt on.so far 104 mph is my best speed.im going to remove the defusor ring from my maximus 5 blades this weekend.
mv35 is offline
Old 10-08-2005 | 09:30 AM
carney's Avatar
Did Chris M. do the drives for you? what power do you have to get 104.
carney is offline
